RobA3 Posted April 23, 2006 Report Share Posted April 23, 2006 Hi guys I need some advice I currently have a 2001 1.8T A3 with the original 16'' wheels. My first question is will 17'' wheels fit with no problems with clearance. secondly I do not anticipate changing the car for at least another year and half, when I will probably buy the current version of the 2.0FSI Sport A3, does that vechile have the same wheel fitment as my current model. Link to comment Share on other sites More sharing options...
Cupramax Posted April 23, 2006 Report Share Posted April 23, 2006 17's will fit fine as long as you get the correct offset ET35 I think...and no the new A3 has different PCD so the only way they will fit is if you get dual drilled wheels with 5x100 & 112 PCD. Link to comment Share on other sites More sharing options...
RobA3 Posted April 23, 2006 Author Report Share Posted April 23, 2006 Thanks for the reply, what does PCD mean by the way Link to comment Share on other sites More sharing options...
Cupramax Posted April 23, 2006 Report Share Posted April 23, 2006 Read the bottom of this page... http://www.rochfordtyres.co.uk/fitmentguide.asp Link to comment Share on other sites More sharing options...
Paul Posted April 23, 2006 Report Share Posted April 23, 2006 P.C.D. stands for pitch circle diameter, and indicates the diameter of the circle in mm connecting the center of each hub bolt your A3 will be 5(bolts) x 100 (mm) New A3 is 5 x 112 hence wont fit. Link to comment Share on other sites More sharing options...
RobA3 Posted April 23, 2006 Author Report Share Posted April 23, 2006 cheers for clarification Link to comment Share on other sites More sharing options...
