neb Posted May 20, 2006 Report Share Posted May 20, 2006 The yellow emmision light started to flash on the speedo and now stays on. The car is misfiring on low rev's Is there any thing I can check or do? Link to comment Share on other sites More sharing options...
mulkbear Posted May 20, 2006 Report Share Posted May 20, 2006 I would strongly suspect that one of the engines cylinders is down of compression, have a compression check carried out to check. Link to comment Share on other sites More sharing options...
neb Posted May 21, 2006 Author Report Share Posted May 21, 2006 thanks for the info Link to comment Share on other sites More sharing options...
LupoBabe Posted May 22, 2006 Report Share Posted May 22, 2006 cld just be the ignition leads... ive had to change mine a few time... can get them fairly cheap to! Link to comment Share on other sites More sharing options...
daz60932 Posted May 24, 2006 Report Share Posted May 24, 2006 I would strongly suspect on you will need a new head (this is talking from experience with all lupos with the same problem) A compression test will be needed to confirm the head is losing compression, make sure one of these tests is carried out before anything else, dont let them fob you off with try this/that/the other. compression test first and go from there Link to comment Share on other sites More sharing options...
