mart2 Posted August 21, 2006 Report Share Posted August 21, 2006 I have a 2000 'w' 115 bhp passat. The number plate lights do not work. I have changed the bulbs but still nothing so i assume its an electrical problem. Is there a fuse somewhere that has blown ? It seems to feed off the same circuit as the boot lock motor. Is that true ? Is there a simple fix to this before I spend money at an auto electrician. Thanks Link to comment Share on other sites More sharing options...
v23 Posted August 21, 2006 Report Share Posted August 21, 2006 Have you checked the fuse box. The manual should have a section in in which interprets the symbols on the fuse box case into their meanings. Link to comment Share on other sites More sharing options...
mart2 Posted August 21, 2006 Author Report Share Posted August 21, 2006 ok, i'll check the fuse box. Only problem is, i dont know where the fuse box is because i dont have that section of the car manual. Could someone point me in the right direction ? thanks Link to comment Share on other sites More sharing options...
guzpot Posted August 21, 2006 Report Share Posted August 21, 2006 should imagine its on the right end of the dash drivers side open the door and you can remove the end panel to display the fuse box. Link to comment Share on other sites More sharing options...
MPTNB Posted August 21, 2006 Report Share Posted August 21, 2006 9 times out of 10 it is caused by a poor earth contact. Identify the earth side of the lights and link a cable to a bare metal part of the car - if it then lights there's your answer. Good luck Link to comment Share on other sites More sharing options...
pugboy Posted August 24, 2006 Report Share Posted August 24, 2006 My rear plate lamps corroded inside so replacing bulb made no odds. Bought new lamp holders. Only a few quid. Link to comment Share on other sites More sharing options...
sparky2076 Posted September 20, 2006 Report Share Posted September 20, 2006 i had same prob turned out to be broken wire in flexi loom to boot lid (on lhs)if you take cover off boot lid (where hazard triangle goes)you can unplug wires to number plate.had to pull new wire in not big job but a bit of a pain.if u pull wires u may find broken one without belling out Link to comment Share on other sites More sharing options...
SteNova Posted September 20, 2006 Report Share Posted September 20, 2006 mine were corroded... so i've ordered in some leds... i'm gonna clean it up, fit the lights then silicone them shut Link to comment Share on other sites More sharing options...
