Fuel tank capacity MK4 R32......
v6tas
US-spec is listed as 16.4 gal (62 liters)
That plus the fuel in the filler neck, and whatever
takes up the space in the top of the tank above
where the filler enters, and it's not all that hard to
believe you got over 62 liters in. One guy in the US has put
18 gallons (68 liters) in repeatedly, but it takes much patience.
Basically fills up the neck and then waits a while, until
it moves into the airspace at the top of the tank, and repeats..
for 5-7 minutes. (Pretty daft if you ask me, but it works)
ian
ian
Yep. Daft. The heat from the exhaust will warm up the tank & the extra bit of fuel that he so carefully fput in will be forced out of the breather pipe (and into the vapour recovery can in the engine bay?)
