redragon Posted September 30, 2006 Report Share Posted September 30, 2006 My EPC and emmission warning lights are on. We don't have a VW service dealer here but I have access to a Vag-com with very limited knowledge to use it. The faults found were; 1. 000818 - knock sensor 2 (G66) : signal too low P0322 - 002 - Lower limit exceeded - intermittent 2. 001537 - internal control module : memory check sum error P0601-001-upper limit exceeded Readiness : 00 10 0000 HELP!!! will the Vag-com be able to solve these problems ? Link to comment Share on other sites More sharing options...
Sebastian Posted September 30, 2006 Report Share Posted September 30, 2006 Could you please post a complete Auto-Scan? Make sure to use the LATEST version of VAG-COM, which is release 607! Any mods? http://www.ross-tech.com/vag-com/download/current.html Link to comment Share on other sites More sharing options...
redragon Posted October 2, 2006 Author Report Share Posted October 2, 2006 I'm not sure how to post the Auto-Scan but I'll try. Just updated the VAG-COM. Thanks for everything. Link to comment Share on other sites More sharing options...
Sebastian Posted October 2, 2006 Report Share Posted October 2, 2006 Use the Copy/Save buttons on the Suto-Scan screen, further instructions can be found here: http://www.ross-tech.com/vag-com/tour/autoscan.html Link to comment Share on other sites More sharing options...
redragon Posted October 2, 2006 Author Report Share Posted October 2, 2006 Sebastian, Here's the scan report; Monday,02,October,2006,21:36:10 VAG-COM Version: Release 607.3-UD Chassis Type: 1K - VW G/J Mk5 Scan: 01 02 03 08 09 0F 15 16 17 18 19 1C 22 25 36 37 3D 42 44 46 47 52 55 56 57 62 65 69 72 76 77 7D VIN Number: WVWZZZ1KZ5W200814 ------------------------------------------------------------------------------- Address 01: Engine Part No SW: 1K0 907 115 A HW: 1K0 907 115 A Component: 2.0l R4/4V TFSI G00 0050 Coding: 040300031C070160 Shop #: WSC 01279 1 Fault Found: 001537 - Internal Control Module: Memory Check Sum Error P0601 - 001 - Upper Limit Exceeded - MIL ON Freeze Frame: Fault Status: 11100001 Fault Priority: 0 Fault Frequency: 1 Mileage: 0 km Time Indication: 0 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 27.0°C Temperature: 27.0°C Absolute Pres.: 1000.0 mbar Voltage: 12.319 V Readiness: 0010 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans Part No SW: 02E 300 042 M HW: 02E 927 770 AD Component: GSG DSG 041 0824 Coding: 0000020 Shop #: WSC 01279 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Part No: 1K0 907 379 K Component: ESP FRONT MK60 0104 Coding: 0004738 Shop #: WSC 01279 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Part No: 1K0 907 044 AB Component: ClimatronicPQ35 066 0404 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Part No SW: 1K0 937 049 N HW: 1K0 937 049 N* Component: Bordnetz-SG H34 0803 Coding: E78F0F0600041800001400001400000000087F075C Shop #: WSC 00020 Part No: 1K2 955 119 B Component: Wischer VW350 012 0401 Coding: 00065493 Shop #: WSC 00020 Part No: 1K0 955 559 M Component: RegenLichtSens 005 0605 Coding: 00218142 Shop #: WSC 00020 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Part No SW: 1K0 909 605 E HW: 1K0 909 605 E Component: 0D AIRBAG VW8R 024 6300 Coding: 0012356 Shop #: WSC 01279 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Part No SW: 1K0 953 549 G HW: 1K0 953 549 G Component: Lenksäulenmodul 521 0050 Coding: 0012142 Shop #: WSC 01279 Part No: XXXXXXXXXXX Component: Lenkradmodul 004 0030 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Part No: 1K6 920 960 D Component: KOMBIINSTRUMENT VDD 0812 Coding: 0007703 Shop #: WSC 00100 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Part No SW: 1K0 907 530 E HW: 1K0 907 951 Component: Gateway H09 0110 Coding: 7F3F0740070003 Shop #: WSC 01279 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Part No: 1K6 920 960 D Component: IMMO VDD 0812 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Part No: 1K0 959 701 G Component: Tuersteuergeraet 09 0120 Coding: 0000054 Shop #: WSC 01279 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Part No: 1K2 909 144 H Component: EPS_ZFLS Kl.12 1502 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Part No: 1K0 959 433 BL Component: 01 KSG 0562 Coding: 98C802087F2D8404085F018010 Shop #: WSC 00000 Component: Sounder n.mounted Component: NGS n.mounted Component: IRUE n.mounted No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Part No: 1K0 959 702 G Component: Tuersteuergeraet 09 0154 Coding: 0000054 Shop #: WSC 01279 No fault code found. ------------------------------------------------------------------------------- Address 55: Xenon Range Part No: 1T0 907 357 Component: Dynamische LWR 0002 Coding: 0000003 Shop #: WSC 01279 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Part No: 1K0 035 186 L Component: Radio BVX 012 0022 Coding: 0040402 Shop #: WSC 01279 No fault code found. ------------------------------------------------------------------------------- Address 62: Door,Rear Left Part No: 1K0 959 703 C Component: Tuersteuergeraet 06 0217 Coding: 0000016 Shop #: WSC 01279 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Part No: 1K0 959 704 C Component: Tuersteuergeraet 06 0217 Coding: 0000016 Shop #: WSC 01279 No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Part No: 1K0 919 283 A Component: 01 Einparkhilfe 0101 No fault code found. End -------------------------------------------------------------------------------------------------- -------------------------------------------------------------------------------------------------------- Link to comment Share on other sites More sharing options...
Sebastian Posted October 2, 2006 Report Share Posted October 2, 2006 [ QUOTE ] Address 01: Engine Part No SW: 1K0 907 115 A HW: 1K0 907 115 A Component: 2.0l R4/4V TFSI G00 0050 [/ QUOTE ] Latest firmware for this ECU is 0060, your dealer should be able to update it and it should also fix the remaining fault code. Of course this only works unless the ECU is not modified. Link to comment Share on other sites More sharing options...
redragon Posted October 2, 2006 Author Report Share Posted October 2, 2006 Thanks Sebastian, I'll try to do that but not sure if my dealer will be able to update the firmware cos they are not official VW dealer. Link to comment Share on other sites More sharing options...
