Folding mirrors!!!
Atomic
Been playing around with my mirror switch trying to get the nearside to dip in reverse... without any luck.
However in the process... I managed to turn the switch fully anti clockwise and the Mirrors folded!!!
Guess I'm gonna go throught the drivers handbook tonight and look for more features smile.gif
One thing puzzles me though... why have folding mirrors if they dont dip in reverse, are they separate features?
Mine too... On a '98 4.2QS.
Mirrors fold and if it's turned to the 'L' and you pop it in reverse the mirror dips. A bit disconcerting until you get used to it.
Didn't realise I had them until I read a post here the other day. Though I'm still looking on eBay to see if there's a kitchen sink or toilet option going cheap smile.gif
Hmm.. suppose you could tap the circuit for the total closure feature when you hold down the locking button to close the windows and sunroof remotely. A couple relays and wiring ought to do the trick grin.gif
Hmm theres a total close?
Is there ? I didnt know that either.
Is this another 'VAG-able' option like the 'lock at 5mph' and 'beep on lock' options?
Don't think it's an option - should be standard. Just keep holding down the 'lock' button on the key until the windows and sunroof have closed. Make sure you hold it down straight away - if you press it brefly and then hold it it doesn't always seem to work.
Mine are listed just inside the warranty book. Codes are:
E0A;4UF;6XE;5SJ;6TS;1KE;J1G;1LX;1AT;1BM;3FG;5MQ;7XO;F0A;OL2;8GT;0G7;0YT;OJH;T7F;8JK;UOL;XB2;1N1;2ZQ;3HA;BQ1;8Z5;MT1;7Q2;C0S;7KO;4X4;3LS;4KC;3YO;4K4;5D1;1SA;5ZO;Q1A;4GP
Pretty hard to tell waht as O's and 0's though :|
Heres the results... Confirms to me that my rear park sensors were a retro/dealer fit as there is no interior on/off switch for it. Strangely though doesnt list my sat-nav... maybe also added later:
E0A = no special edition
4UF = drivers and front passenger airbag with front passenger airbag deactivation
6XE = outer rear view mirrors: powered, heatedelectrically foldable
5SJ = outer left rear view mirror: convex
6TS = outer right rear view mirror: non-spherical, large viewing field
1KE = disc brakes, rear
J1G = battery 450 A (92 Ah)
1LX = disc brakes, front
1AT = electronic stabilization program (ESP)
1BM = standard suspension/shock absorption
3FG = electric sliding/pop-up glass sunroof retractable
5MQ = decorative leatherette inserts
7X0 = without park distance control
F0A = no special purpose vehicle, standard equipment
0L2 = electric throttle actuation
8GT = compact alternator 90 - 150A
0G7 = Tiptronic
0YT = weight category rear axle weight range 17
0JH = weight category front axle weight range 8
T7F = components for, base engine, unit 078.2
8JK = ellipsoidal headlight for driving on the left
U0L = instrument insert with tachometer clock and mph speedometer
X2B = national sales program Great Britain
1N1 = power steering
2ZQ = leather trimmed multi-function steering wheel for airbag system
3HA = without leather parts scope
8Q1 = headlight-range adjustment
8Z5 = engine cooling system, type 1
MT1 = 6-cylinder gasoline engine 2.8 L/142 kW 30V, base engine is T7F
7Q2 = navigation system with color screen
C0S = forged alloy wheels 8J x 17 five-arm style, offset 48
7K0 = without tire pressure warning light
4X4 = side airbag, front and rear with curtain airbag
3LS = Alcantara door and side panel trim
4KC = side and rear windows tinted
3Y0 = without roll-up sun screen
4K4 = radio remote controlled central locking operated from inside and separate trunk release
5D1 = carrier frequency 433.92 MHz
1SA = without additional engine guard
5Z0 = without separate power seats rear
Q1A = standard front seats
4GP = windshield tinted with sun band and viewing window for vehicle identification number
