mkchappo Posted January 5, 2007 Report Share Posted January 5, 2007 I have been trying to adjust the clock on my car. I have looked in the MMI manual and it says use the 'Time' option from any setup screen from the MMI. It shows the 'Time' option as the top left hand quarter button. I have been to every setup screen and have not been offered a 'Time' option on any of them. But all the top left hand quarters are blank? Am I missing something? Link to comment Share on other sites More sharing options...
MACH1 Posted January 8, 2007 Report Share Posted January 8, 2007 On my Audi A6 2001 X Reg, You pull the button out to the right of the display, the hour display will flash, then turn the button to the left or right to alter the hour, to alter the minutes keep pulling the button out until the minutes flash then turn left or right to set time, the same goes for setting the date. I hope this helps. Link to comment Share on other sites More sharing options...
DNay Posted January 8, 2007 Report Share Posted January 8, 2007 [ QUOTE ] I have been trying to adjust the clock on my car. I have looked in the MMI manual and it says use the 'Time' option from any setup screen from the MMI. It shows the 'Time' option as the top left hand quarter button. I have been to every setup screen and have not been offered a 'Time' option on any of them. But all the top left hand quarters are blank? Am I missing something? [/ QUOTE ] press the CAR button on the console next press SET UP (also on the console button) - this comes up with a message of no further settings available. However,in the top RH quarter of the screen, SETTINGS shows. press the appropriate button on the console to select. This will bring up the following options on the main screen: Menu language measurement units time settings Select time settings and you should be where you need to be to change either the time, date or the format of either. hope this helps. Must admit when I got to the bit about no further settings available I was stumped for a bit. Link to comment Share on other sites More sharing options...
