Brisel Posted June 3, 2007 Report Share Posted June 3, 2007 Does anyone have any good tips on how I can remove my headlight protectors without damaging them or the bodywork? It's a MK IV R32 with standard VW protectors. TIA Link to comment Share on other sites More sharing options...
Gti_Fly Posted June 3, 2007 Report Share Posted June 3, 2007 slide them gently towards the middle of the car (slide them about 1-2cm), and this usually loosens the tension enough for them to be carefully lifted out from the bottom of the headlamp. Link to comment Share on other sites More sharing options...
dubzter Posted June 4, 2007 Report Share Posted June 4, 2007 the only way to remove them is very carefully as I found out to my expense. Good luck. I broke one and never replaced it then had to replace the headlight ionstead. That was a sore one I can tell you Link to comment Share on other sites More sharing options...
Jeffers Posted June 4, 2007 Report Share Posted June 4, 2007 I've found them to be pretty easy - they kind of clip over the bottom of the headlight so a firm but careful pull at the bottom of the protector should bring it away from the light and and then you can unhook it from the top. Do all this with the bonnet ope though and careful not to knock the clip at the top off and into the engine bay! Link to comment Share on other sites More sharing options...
v6tas Posted June 4, 2007 Report Share Posted June 4, 2007 [ QUOTE ] Does anyone have any good tips on how I can remove my headlight protectors without damaging them or the bodywork? It's a MK IV R32 with standard VW protectors. TIA [/ QUOTE ] I remove mine everytime it gets washed mate. It couldnt be easier. Gently ease the protector out from the bottom with the bonnet open and then flip them off the catch, jobs a goodun Link to comment Share on other sites More sharing options...
Brisel Posted June 4, 2007 Author Report Share Posted June 4, 2007 Thanks guys Link to comment Share on other sites More sharing options...
