Davef Posted June 16, 2008 Report Share Posted June 16, 2008 Hi all, For reasons I can't explain I am well along the way to retrofitting full front and rear PDC to my A4 avant. I have front and rear bumpers with the appropriate sensors painted and ready to go. I have full wiring spec, 8 channel control unit and the kufatec looms and have sorted out most of the issues. However I need to make connections to the convenience can high and low and gala and kufatec recommend connecting into the plugs on the instrument cluster for this. The rest of the wiring is fairly straight forward. Does anyone know where the dash panel harness can connectors or other more accessable can connections are located? If there is interest in this I will do a "how to guide" when complete Cheers, Dave Link to comment Share on other sites More sharing options...
shark_90 Posted June 16, 2008 Report Share Posted June 16, 2008 There is no how to guide, but I'd be happy to help you if you fancy an afternoon tinkering. I'm in Worksop. Link to comment Share on other sites More sharing options...
Davef Posted June 16, 2008 Author Report Share Posted June 16, 2008 Hi Shark, Might take you up on that - just need to get clear in my mind the best way to do it before I start. I cant find anyone who has done the full PDC retrofit so the "how to" will be written if I can make it all work!! Dave Link to comment Share on other sites More sharing options...
shark_90 Posted June 16, 2008 Report Share Posted June 16, 2008 Well I can do the electronicy bits and probably sus the coding out if you can do the greasy bits - or do those bits first perhaps? Link to comment Share on other sites More sharing options...
nisiotis Posted February 8, 2009 Report Share Posted February 8, 2009 Hi! I know is been long time since you did this, but I am willing to do it too. I have bought allmost everything apart from the bumbers. I would like to know a few things: where are the beepes located? (Front and rear - any pictures? where are the mounting points) where is the controller located - any pictures where are the mounting points? are there any pictures retrofitting it? and last but not least where do you pass through the cables? (from interior to exterior and engine compartment to interior?) thanks My car is an A4 1.8T Quattro B7 Vasilis Link to comment Share on other sites More sharing options...
