winrya
Is this a good price for retrofit cruise control?
30 posts in this topic
Hi, I've had the GTI for 9 weeks now and one thing i am really missing is cruise control. I've just spoken to my local dealer and they will fit it to my car for £170 which sounds very reasonable to me. What do you guys think?
Regards
Ryan
Think that's cheaper than a factory fitted option?
If you'll use it on a regular basis then £170 is a very good price and it looks like you've used cruise before, so I'd get it fitted mate 169144-ok.gif
Yea had it on my previous alfa and thought it was brilliant in areas of speed cameras and 30,40,50,60 limits where i always find myself concentrating so much on the speedo as to not get flashed, cruise takes a bit of stress out of driving, just set at the limit and concentrate on the road, traffic and conditions.
Im due a service in 500 miles and ive been quoted £150 for the 1st service, sounds quite reasonable to me, is this the norm? Think I'll get cruise fitted at the same time laugh.gif
Someone got it done for 150 all in at a dealer (read it just on UKMKIVS) so tell them that and I am sure they will discount it a bit..
Remember, they want your business. The kit alone costs only 50 quids
That is a good price. Are they using all original equipment parts - stalk etc??
yes all oem stuff, so no different from having it fitted from the factory
the cruise buttons are on the left stalk and not the steering wheel.
It's a bargain when companies like AmD are doing it for £299 + VAT SMOKE6.GIF
Mines a manuel with midline comp. Do you set useing stalk and does it show up on midline DIS?
wow i am sooooo glad i read this post, amd was about to do the work for 327 fitted.. hmm looks like it is cheaper then that!!..
The cruise on/off is on top of the stalk with the increase /decrease speed settings on the end of the stalk.
A green warning light appears in the speedo housing section when you have it operating rather than in the Midline display. 169144-ok.gif
does the speed, or do you have to reach the desired speed then set?
Turn it on whilst driving, get to speed required.
Press upper rocker switch on stalk end to set that speed.
You can also adjust speed up or down by single push of the appropriate switch on stalk end having already set a previous speed say.
Is it the same way for DSG Highline?
Or can you seta speed and the car gets up to that speed?
1. Yes.
2. No, the car just maintains the speed you've 'set' once you're there.
How many miles have you done in 9 weeks?!
Thats piss poor.
In BM's and Merc's you can be doing 10mph, set the cruise to 90 and the car takes off.
I take it that if u brake, accelerate it disingages.
The other thing to watch out for is the slowest speed the cruise can do - with more and more 20mph limits, be sure that the retrofit you get will do this!
