K800i bluetooth problem
RobK
I keep getting this problem when trying to make a call from my K800i, it says "connecting" on the screen but there is no dial tone. I then have to press hang up, after which the phone reboots itself.
Anyone else had this, and is there a fix? The phone has the Vodafone firmware btw.
never had this issue with my K800i.....
Make sure it is fully connected first - i.e. you get the little headset symbol on the phone screen. Sounds daft, but you never know! Mine only paired sometimes with my old Parrot kit in my old car and did what you describe before making a call, then fully connecting to the kit and dialling.
My firmware was a very old version until last night and it worked perfect. It is now running K810i firmware and still works fine.....
Let us know how you get on and i can try replicating at this end!? Somehow..... znaika.gif
How did you update it to K810 firmware, and what is the advantage of doing that?
used 'wotanserver'. Only real advantage is that it gets Track ID from the Walkman software. Oh and the Themes are nicer!! 169144-ok.gif
  • 3 months later...
