AGK512 Posted September 24, 2007 Report Share Posted September 24, 2007 Hi all After an errpr of judgement I needed to reverse about 200 yards up a very narrow very steep very bendy hill If I didn't have DSG and reverse sensors I would have been stuffed and it would have been a good laugh for VW assistance ! It took about 10 mins to get back to the top of the hill with several stop starts (as few as possible but it was "impossible" ) When almost at the top the gear indicator row on the MFD started to flash like a christmas tree ! and I lost drive. I guess this was the DSG box shouting ENOUGH ! your cooking the clutch and you could smell it ! So I switched off counted to 10 and started up again, regained drive to do the final shallow bit of the climb and then went the correct way !! Engine was running for about another 5 mins after "christmas tree" so hopefully had chance too cool gently ! I drove 250 miles home two days later and apart from a smidge more shunt on the occasional change all seemed OK If I take it in will anything show up on the diags ? is a DSG clutch classed as a "wear and tear" item ? can the be changed ? Anyone else managed to do this Link to comment Share on other sites More sharing options...
petsy Posted September 24, 2007 Report Share Posted September 24, 2007 the clutches can be changed but, afaik, for the unmodified standard car should last for "life". I suspect that most dealers will change the dsg box if there's a problem instead of tinkering with it. Link to comment Share on other sites More sharing options...
mlhj83 Posted September 24, 2007 Report Share Posted September 24, 2007 It's normal for DSG to cut/reduce drive transmission if it reaches a point of overheating. The same thing happens if you use launch control a few times in succession. Your gearbox should be fine. But for your peace of mind, just have it checked at the dealers. Link to comment Share on other sites More sharing options...
AGK512 Posted September 25, 2007 Author Report Share Posted September 25, 2007 Thanks for the replies. will probably drop it in next week ... you been using too much LC then Link to comment Share on other sites More sharing options...
