Child Lock Problem
stooH
I had to put the child lock on my rear passenger side door the other day and put my key in to turn it and the black 'button' you put the key into popped inside the door!
I need to take it into the dealers to have a look but I was after opinions:
a) will it be a big job to fix as I guess they'll have to take off the door panel to retrieve
b) is it likely to be a warranty job? I know that I caused it but it was hardly like I went at it with a hammer. I stuck the key in and in it popped.
Other cars I've been in have had nice little switches or something proper built into the door, why the flimsy piece of plastic?!
Update:
I'm a tw@t!
It appears that what I presumed was the child lock is in fact not. It's a rubber bung which happens to have a picture of a lock on it. The child lock is actually on the inside edge of the door and is a nice sturdy bit that you put the key into. smashfreakB.gif
Which begs the question, what is the rubber bung with a lock on it for and is there any issue with me leaving it with the bung inside the door?
