boraallthewey Posted January 19, 2008 Report Share Posted January 19, 2008 hi all, i have been looking around the net for a good xenon kit. what do you think about the hid conversion kits on this site ? thanks in advance Link to comment Share on other sites More sharing options...
Rustynuts Posted January 20, 2008 Report Share Posted January 20, 2008 First things first. I take it from your username (Bora) that you're in the UK. Well, the site you're looking at is a US site so that may influence your choice. They might look cheap but Customs might make it a little less cheap when they arrive in this country. There'll be VAT to pay and probably Import Duty aswell. Second, your Bora has H4 headlight bulbs. This is a single bulb that has 2 filaments doing both dip beam and main beam. Golfs on the other hand have 2 bulbs, one for dip which remains on all the time and one for main beam which supplements it when required. For your headlights to work correctly you need either a VWxenon headlight (uses the foglight location for dipped xenon) or a "shifting" bulb which flicks back and forward to do both beams when you flick the switch. Be careful ordering a kit that costs the same for an H4 fitment as an H7, as you might end up with a kit that just gives you dip beam. There are suppliers in this country that sell these kits. Link to comment Share on other sites More sharing options...
benjie Posted January 20, 2008 Report Share Posted January 20, 2008 I got mine from the US and the duty is roughly £25 IF they catch you! As Rusty said, you need H4 BI-Xenon, otherwise you'll end up with just dipped beam and no main beam = MOT failure! Link to comment Share on other sites More sharing options...
mb Posted January 31, 2008 Report Share Posted January 31, 2008 I believe no headlight washers or self levelling should also be an MOT failure - there was a discussion in general cars recently Link to comment Share on other sites More sharing options...
benjie Posted January 31, 2008 Report Share Posted January 31, 2008 I was under that vague impression too, but mine's passed 2 MOT's at 2 different garages. Was there something about the headlight washers/levelling rule only being applicable to OEM/factory fit? Link to comment Share on other sites More sharing options...
Tristan177 Posted July 23, 2008 Report Share Posted July 23, 2008 I believe no headlight washers or self levelling should also be an MOT failure - there was a discussion in general cars recently yep... U R right... MOT fail if you dont have these.... this applies in ALL countries.. Link to comment Share on other sites More sharing options...
