Jimmer01225 Posted February 20, 2008 Report Share Posted February 20, 2008 Hi Guys, I have not been on the forum for a while. My D3 has been getting a few problems, so I took it down to the local independent for a diagnosis. A new coolant sensor has sorted most things but I still have a problem with my parking brake. I think there used to be a Vag Com page but I can't find this now. Please could anyone tell me what the fault below from the Vag-Com log might mean? most of the time the parking brake works just fine, sometimes it does not release but by operating the switch a couple of times its all ok again. I've had this fault ever since the stealer fitted new rear pads about 2 years ago. Address 53: Parking Brake Labels:None Part No SW:4E0 910 801 HW:4E0 907 801 Component: EPB A01H011 H01 0110 Coding: 0000531 Shop#:WSC 00428 1 Fault Found: 16347 - Control Module - EEPROM Error 014 - Defective - MIL ON Freeze Frame: Fault Status: 11100000 Fault Priority:4 Fault Frequency: 176 Time Idication:0 Freeze Frame: Voltage:10.87 V Count: 187 Thanks Link to comment Share on other sites More sharing options...
thepm Posted February 21, 2008 Report Share Posted February 21, 2008 Hi I don't know if this relates but before I picked up my car (a 2003 D3 4.2) I know there had been some work on the parking break. I believe it may have been a recall. I do not have any more info than that but it might be worth a phone call to a main dealer to see if there is a recall on your car. The only other thing I know is that you have to enter the correct pad depth into the computer when you replace the pads. Philip Link to comment Share on other sites More sharing options...
Jimmer01225 Posted February 21, 2008 Author Report Share Posted February 21, 2008 Thanks, I will give the dealer a ring and check this out. Link to comment Share on other sites More sharing options...
NG Jon A8 Posted April 16, 2008 Report Share Posted April 16, 2008 Most likely brake pedal switch mate. Common problem on the D3's. Link to comment Share on other sites More sharing options...
