zip Posted March 4, 2008 Report Share Posted March 4, 2008 Hi, What are you guys using for ipod integration? Tempted to go down the Dension 100 route, but a bit put off with the apparent restriction of only playing playlists. Although the integrated bluetooth handsfree module sounds interesting. I am going to strip out an old nokia handsfree kit anyway. Thoughts? Zip 2002 S8 Link to comment Share on other sites More sharing options...
Joylove Posted March 4, 2008 Report Share Posted March 4, 2008 Strip out the old nokia? Chances are with a CK-20w and a Autoleads 06-208B you could be Bluetoothed up. (Check the connectors before purchase, but seriously it's just power, GND, mute, IGN, mic and speaker, so you could even cut off the car connector and connect up a bluetooth car kit) Link to comment Share on other sites More sharing options...
thenamesross Posted March 6, 2008 Report Share Posted March 6, 2008 re the Denison, radio presets 1-5 plays the 1st 5 playlists on your pod but if you unplug it, select something else on your pod it will play that when you plug it back in. You can also use preset 6 to manually scroll through your ipod using the << and >> buttons. Cant remeber exactly how that one works though. Link to comment Share on other sites More sharing options...
IceBlue8 Posted March 7, 2008 Report Share Posted March 7, 2008 I've got this in my A8 and I thought that it was faulty because it only played 5 play lists! Any idea where I can find instructions to get the 'and' feature to work on preset 6? Link to comment Share on other sites More sharing options...
thenamesross Posted March 7, 2008 Report Share Posted March 7, 2008 Check which type you have. Should be able to download the manual here, http://www.dension.com/download_icelink.html Link to comment Share on other sites More sharing options...
