Figure11 Posted April 9, 2008 Report Share Posted April 9, 2008 Anyone tell me where the fuze for the radio is. Seems I must have popped it while trying to fit the PC. Anyway it don't work now and neither does my ELSA Win or VAGCom on my new laptop! Mike Link to comment Share on other sites More sharing options...
PsYcHe Posted April 9, 2008 Report Share Posted April 9, 2008 In the cubby beside the accelerator pedal (be careful as you take it off or you'll break off the plastic from the pedal like I did). Black fuse carrier number 9 is for the on-board diagnostics (10A), also maybe yellow carrier number 1 (15A). In the boot, fuse 3B is the radio fuse, third row from the front (15 or 20A). Good luck Also, not sure if I saw a little fuse on the back of my radio when I had it out to fit the car kit. Link to comment Share on other sites More sharing options...
Figure11 Posted April 10, 2008 Author Report Share Posted April 10, 2008 In the cubby beside the accelerator pedal (be careful as you take it off or you'll break off the plastic from the pedal like I did).Black fuse carrier number 9 is for the on-board diagnostics (10A), also maybe yellow carrier number 1 (15A). In the boot, fuse 3B is the radio fuse, third row from the front (15 or 20A). Good luck Also, not sure if I saw a little fuse on the back of my radio when I had it out to fit the car kit. Spot on, top banana. Thanks. Mike Link to comment Share on other sites More sharing options...
