AsianMpower Posted April 14, 2008 Report Share Posted April 14, 2008 I have recently bought a mk5 gti with 60k miles in red with manual gear select. i dont know if its me but i find that this gti is slower than my previous one which was a dsg. it was along time ago when i had the previous one but i find it takes abit of time building up the power and then moving, now i am not sure if its because i was use to a NA car or there something not right? any suggestions would be a big help thanks! Link to comment Share on other sites More sharing options...
JonnyGTi Posted April 14, 2008 Report Share Posted April 14, 2008 You could get the power and torque tested on a rolling road ? Have you checked the Forge DV out - any hissing etc. ? - a lot of these have split / leaked. Are you using Superunleaded petrol ? Link to comment Share on other sites More sharing options...
TwoSheds Posted April 14, 2008 Report Share Posted April 14, 2008 I have recently bought a mk5 gti with 60k miles in red with manual gear select.i dont know if its me but i find that this gti is slower than my previous one which was a dsg. it was along time ago when i had the previous one but i find it takes abit of time building up the power and then moving, now i am not sure if its because i was use to a NA car or there something not right? any suggestions would be a big help thanks! If I were you I would find a mate, with Vag-Com, to run a check for any fault codes showing to start with. If you've just bought it through a dealer ask them to run a check on their computer saying you're not happy & would like it checked out as you think something is wrong. Link to comment Share on other sites More sharing options...
AsianMpower Posted April 14, 2008 Author Report Share Posted April 14, 2008 You could get the power and torque tested on a rolling road ?Have you checked the Forge DV out - any hissing etc. ? - a lot of these have split / leaked. Are you using Superunleaded petrol ? yes i do hear the dump valve when changing gear is this normal or is there a problem with the valve? Link to comment Share on other sites More sharing options...
AsianMpower Posted April 14, 2008 Author Report Share Posted April 14, 2008 If I were you I would find a mate, with Vag-Com, to run a check for any fault codes showing to start with.If you've just bought it through a dealer ask them to run a check on their computer saying you're not happy & would like it checked out as you think something is wrong. good idea mate i might just book it into vw to check that. is there no onboard code checker? Link to comment Share on other sites More sharing options...
petsy Posted April 14, 2008 Report Share Posted April 14, 2008 if you know someone with a vag-com then you could check for stored fault codes. Link to comment Share on other sites More sharing options...
Snoopy Posted April 16, 2008 Report Share Posted April 16, 2008 Something i often do when buying a secondhand car is find out from magazine reviews the ingear figures. Things like 30-50 in 3rd, 50-70 in 5th/6th. Then use a flat bit of road and ruffly time it. Its a good basic, no cost and hassle free indicator that a cars running near spec. Link to comment Share on other sites More sharing options...
