PeterS Posted May 24, 2008 Report Share Posted May 24, 2008 Our 8P A3 Special Edition has what are quite possibly the dullest wheels that Audi make. They're 16" 9 spoke wheels that might as well be plastic hubcaps :flush:. Now ever since I had a B6 Avant with the 17" 5 spoke 'Star' alloys (free upgrade with the 'sport' spec back in '03!!) I've really liked them, and think they suit the A3 very well too. They're also easy to clean :D There are always a few sets for sale on Ebay, but many are from the A4 not the A3. Will A4 wheels fit an A3? Thanks Peter Link to comment Share on other sites More sharing options...
shark_90 Posted May 24, 2008 Report Share Posted May 24, 2008 Yes, is the short answer. But it would be wise to check the offset of the wheels to try and stay close to what you are currently running. The offset number is usually written as ET35 or similar. I think A4's are usually around ET45, I don't know what your current A3 wheels are but you'd be best to stick to roughly what it is at present or at least within a 2-3 ET (millimetres). A smaller offset will stick out more, so you'll probably be ok with a smaller offset within reason. A bigger offset will stick out less, which could cause fouling of suspension or steering arms etc. Link to comment Share on other sites More sharing options...
PeterS Posted May 24, 2008 Author Report Share Posted May 24, 2008 Thanks shark_90 - I'll check the spare; I guess the offset will be stamped on that somewhere Peter Link to comment Share on other sites More sharing options...
Nelson_R32 Posted June 7, 2008 Report Share Posted June 7, 2008 A3's of 8P chassis normally run around ET51+ whereas A3's have an offset of around ET38-ET44 If you fit A4 wheels, you need to be sure of the following; 1) That you only fit 18's - as you can't fit any lower than ET44 to an A3 without rubbing 2) That you don't keep A4 sized tyres on the wheels, as again you will get rubbing. Link to comment Share on other sites More sharing options...
gorgalor Posted January 27, 2010 Report Share Posted January 27, 2010 PeterS: I came across this post googling the same question you had. I was wondering if you went ahead and fitted A4 wheels on to your A3 yet? If so, any problems? Thanks! Link to comment Share on other sites More sharing options...
gorgalor Posted January 30, 2010 Report Share Posted January 30, 2010 Just upgraded to black rims (sourced from an a4, year unknown) on my 2007 A3: <img src="http://i841.photobucket.com/albums/zz334/gorgalor/blackrims.jpg?t=1264895751"> Link to comment Share on other sites More sharing options...
