bkarathan Posted July 3, 2008 Report Share Posted July 3, 2008 dear sirs im facing a problem with the use of a/c . i noticed that after a few hours of climate system turned on , the windscreen and the other windows misting-up on the inside. it is something like a visible film appears on the windows and make them blurring. This film get away only with to rub it lightly with a water cloth or paper what is the problem ? does anything toxic or harmfull air gets into the cabin? thanks a lot babis karathanasis a4, 1.6 2000 model Quote Link to comment Share on other sites More sharing options...
maersk Posted July 3, 2008 Report Share Posted July 3, 2008 Have you inadvertently left recirc on? Quote Link to comment Share on other sites More sharing options...
no_idea Posted July 3, 2008 Report Share Posted July 3, 2008 Has the pollen filter been replaced recently, these can get wet and cause misting. Quote Link to comment Share on other sites More sharing options...
bkarathan Posted July 4, 2008 Author Report Share Posted July 4, 2008 no i havent left recirc on and the filter is new only two months Quote Link to comment Share on other sites More sharing options...
MrAvant Posted July 4, 2008 Report Share Posted July 4, 2008 Is your Air-con working and does it get cold when placed on the lowest setting? Quote Link to comment Share on other sites More sharing options...
Biscuits Posted July 4, 2008 Report Share Posted July 4, 2008 Had this on our MKIV Golf. Check the outside temperature is reading okay, the sensor on ours was faulty and IIRC every now and then it would read -17 degrees. This causes the compressor (air-con) to switch off and any moisture in the system to come through and steam the car up. Another thing that went wrong was the rear washer hose came off and filled the headlining with water... this caused a horid pond smell and also extra misting. Ahhhh.... that was a good part ex day :D :D :D Quote Link to comment Share on other sites More sharing options...
bkarathan Posted July 7, 2008 Author Report Share Posted July 7, 2008 Is your Air-con working and does it get cold when placed on the lowest setting? ya it works fine when i placed on the lowest setting and the outside temper works fine also Quote Link to comment Share on other sites More sharing options...
