windscreen misting due to climate problem?
bkarathan
dear sirs
im facing a problem with the use of a/c . i noticed that after a few hours of climate system turned on , the windscreen and the other windows misting-up on the inside. it is something like a visible film appears on the windows and make them blurring. This film get away only with to rub it lightly with a water cloth or paper
what is the problem ? does anything toxic or harmfull air gets into the cabin?
thanks a lot
babis karathanasis
a4, 1.6 2000 model
Had this on our MKIV Golf.
Check the outside temperature is reading okay, the sensor on ours was faulty and IIRC every now and then it would read -17 degrees.
This causes the compressor (air-con) to switch off and any moisture in the system to come through and steam the car up.
Another thing that went wrong was the rear washer hose came off and filled the headlining with water... this caused a horid pond smell and also extra misting.
Ahhhh.... that was a good part ex day :D :D :D
