Audi A4 (8E-B6): 1) Instrument coding, 2) Trip Computer and Cruise Control fitting
sermike75
Hello everybody from Greece,
I just bought a VAG-COM HEX-USB+CAN cable and i want to make some changes to my car.
My questions are:
1. Is it possible to enable Seat-Belt warning (on the DIS or beep)?
If yes what is the coding;
2. Can i retrofit Trip Computer and Cruise Control with module 8E0 953 549 N, or i need an other module?
What is the coding for them?
Thank you
After auto-scan with Vag-Com i have these results:
Monday,30,June,2008,12:48:49:47100
VCDS Version: Release 805.0
Data version: 20080625
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUZZZ8E04A1xxxxx Mileage: 97790km/60763miles
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 LJ
Component: 1,9l R4 EDC 0000SG 4910
Coding: 00002
Shop #: WSC 63251
WAUZZZ8E04A1xxxxx AUZ6Z0C032xxxx
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 3429
Coding: 04255
Shop #: WSC 37605
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AA
Component: A4 Klimaautomat 1319
Coding: 00000
Shop #: WSC 63251
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 C
Component: int. Lastmodul RDW 0606
Coding: 00001
Shop #: WSC 63251
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 J
Component: Airbag 8.4EP 1002
Coding: 0010602
Shop #: WSC 63251 000 00000
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenks?ulenmodul 0611
Coding: 00001
Shop #: WSC 37605
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 900 K
Component: KOMBI+WEGFAHRS. RB4 D38
Coding: 00000
Shop #: WSC 00001
Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
Part No: 8E0 959 433 AR
Component: Komfortger?t T85 1310
Coding: 06720
Shop #: WSC 63251
Part No: 8E1959801B
Component: T?rsteuer.FS BRM 0003
Part No: 8E1959802B
Component: T?rsteuer.BF BRM 0003
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 186 L
Component: concert II GRO 0001
Coding: 01001
Shop #: WSC 63251
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 HW: 8P0 862 335
Component: FSE_255x H10 0090
Revision: 00000001 Serial number: 00000000022055
Coding: 0000511
Shop #: WSC 00000 000 00000
End ---------------------------------------------------------------------
I read the wiki.ross-tech and I think that my car is in category 8E2/8E5/8H7.
When i connect vag-com i have K1,K2:OK and no Canbus.
So, if i want to enable seat-belt for country Greece the code is 00131 or 02131 or something else? :confused:
