New member - with a climatronic question!
Mr Dillinga
Hey Guys,
First post here so hello! Got my '07 GTi 2 weekends ago and have a question about the climatronic...
Today for instance, I'm driving back and its 19.5 outside so I turn the blower on one notch (which should be manual). I had the temp set to LO but the fan then decided to go all the way eventually to full blast. I had to turn it back to one bar and then it stayed.. I'm pretty sure it didn't do this the other morning although I think I may have been in auto mode at the time..
Is this normal behaviour? Something to do with the outside temp and the LO setting?
Thanks in advance
Sorry not very clear. The temp is the temp regardless of the power. But auto will keep it at that temp i.e. changing the force of air. Manuel will continue to blow out 16 if thats what you have selected which in theory means it might be 14 in the car but still blasting out 16. I think blowing out cold air on full blast is normal when first selecting manuel
I think you'll find the heating system has a mind of its' own. Even if not set to 'Auto' when you turn the temp down to LOW the fan will go crazy.
I prefer to control the heating myself (mainly because auto mode is pants) but the fan speed still changes itself sometimes. Also when I set the temp to around 22 degrees the 'Auto' light switches on. Wierd and annoying.
