safety69 Posted July 28, 2008 Report Share Posted July 28, 2008 I recently purchased a 53 plate S3 with 43,000 miles from my local Audi dealership still with in the 30 day exchange plan and I already have issues with the electric seats etc not working.....starting to wonder if they actually did a multi point car check. I have put together a list of faults/issues i have with the car for correcting and decided to run a fault code check to see if there were any....the results are below. I am most concerned with the Engine, Airbag and Haldex. Are this fault codes to worry about and should Audi have fixed them before selling the car to me? Monday,28,July,2008,19:46:09:37091 VCDS Version: Release 805.0 Data version: 20080625 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 8L - Audi A3/S3 Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76 VIN: WAUZZZ8L831211863 ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No: 8N0 906 018 BP Component: 1.8L R4/5VT 0002 Coding: 10710 Shop #: WSC 01236 WAUZZZ8L831211863 AUZ7Z0B2287140 1 Fault Found: 18010 - Power Supply Terminal 30: Voltage too Low P1602 - 35-10 - - - Intermittent Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8N0-907-379-MK20-E.lbl Part No: 8N0 907 379 E Component: ESP 20 CAN V005 Coding: 18448 Shop #: WSC 01236 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: Redir Fail! Part No: 8L0 820 043 K Component: A3 KLIMAAUTOMAT 0105 Coding: 00041 Shop #: WSC 01236 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8L0-959-655-AI8.lbl Part No: 8L0 959 655 L Component: Airbag Front+Seite 7008 Coding: 01104 Shop #: WSC 01236 1 Fault Found: 00532 - Supply Voltage B+ 07-10 - Signal too Low - Intermittent ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8L0-920-xxx-17.lbl Part No: 8L0 920 980 R Component: KOMBI+WEGFAHRS. VDO D11 Coding: 01444 Shop #: WSC 00137 WAUZZZ8L831211863 AUZ7Z0B2287140 1 Fault Found: 01304 - Radio 49-10 - No Communications - Intermittent ------------------------------------------------------------------------------- Address 22: AWD Labels: 02D-900-554.lbl Part No: 02D 900 554 C Component: HALDEX LSC ECC 0010 2 Faults Found: 00526 - Brake Light Switch-F 27-10 - Implausible Signal - Intermittent 00532 - Supply Voltage B+ 07-10 - Signal too Low - Intermittent ------------------------------------------------------------------------------- Address 35: Centr. Locks Labels: 8D0-862-257.lbl Part No: 8D0 862 257 E Component: CV-Pump, Alarm, RC D17 Coding: 15178 Shop #: WSC 00137 7 Faults Found: 01367 - Central Locking Pump Run Time Exceeded (Likely Leak) 35-00 - - 01371 - Alarm triggered by Door Contact Switch; Driver's Side 35-00 - - 01374 - Alarm triggered by Terminal 15 35-00 - - 01370 - Alarm triggered by Interior Monitoring 35-00 - - 01365 - Lock/Unlock Switch; Interior 29-00 - Short to Ground 00991 - Interior Lights 28-00 - Short to Plus 00955 - Key 1 09-00 - Adaptation Limit Surpassed ------------------------------------------------------------------------------- Address 45: Inter. Monitor Labels: 4B0-951-173.lbl Part No: 4B0 951 173 Component: Innenraumueberw. D03 Coding: 00001 Shop #: WSC 00000 No fault code found. ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl Part No: 4B0 907 357 Component: LEUCHTWEITEREGLER D004 Coding: 00014 Shop #: WSC 01236 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: None Part No: 8L0 035 195 H Component: symphony II NP2 0151 Coding: 00201 Shop #: WSC 00272 No fault code found. End --------------------------------------------------------------------- Monday,28,July,2008,20:03:14:37091 VCDS Version: Release 805.0 Data version: 20080625 Link to comment Share on other sites More sharing options...
khufu Posted July 28, 2008 Report Share Posted July 28, 2008 Im guessing her, 1st one means battery has either gone flat or been changed 2nd possibly is dodgy side airbag connector, under driver seat is often culprit 3rd bad connection between radio and instrument cluster, possibly at cluster end? 4th the brake light switch has been/is faulty 5th drivers door has activated alarm to be honest, I would have hoped they would have cleared these all before they sold it to you.... Link to comment Share on other sites More sharing options...
Hopsta Posted July 31, 2008 Report Share Posted July 31, 2008 Take a print out with them all on and ask them to explain why they weren't resolved beofre you bought it.. should soon get a reaction Link to comment Share on other sites More sharing options...
Mollox Posted July 31, 2008 Report Share Posted July 31, 2008 "01367 - Central Locking Pump Run Time Exceeded (Likely Leak)" I've had this on mine for about 5 years. Doors lock and unlock, no noticeable problems Link to comment Share on other sites More sharing options...
