[Audi A3/S3] 8L S3 Fault Codes
safety69
I recently purchased a 53 plate S3 with 43,000 miles from my local Audi dealership still with in the 30 day exchange plan and I already have issues with the electric seats etc not working.....starting to wonder if they actually did a multi point car check.
I have put together a list of faults/issues i have with the car for correcting and decided to run a fault code check to see if there were any....the results are below. I am most concerned with the Engine, Airbag and Haldex. Are this fault codes to worry about and should Audi have fixed them before selling the car to me?
Monday,28,July,2008,19:46:09:37091
VCDS Version: Release 805.0
Data version: 20080625
Chassis Type: 8L - Audi A3/S3
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
VIN: WAUZZZ8L831211863
Address 01: Engine Labels: Redir Fail!
Part No: 8N0 906 018 BP
Component: 1.8L R4/5VT 0002
Coding: 10710
Shop #: WSC 01236
WAUZZZ8L831211863 AUZ7Z0B2287140
1 Fault Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8N0-907-379-MK20-E.lbl
Part No: 8N0 907 379 E
Component: ESP 20 CAN V005
Coding: 18448
Shop #: WSC 01236
No fault code found.
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 8L0 820 043 K
Component: A3 KLIMAAUTOMAT 0105
Coding: 00041
Shop #: WSC 01236
Address 15: Airbags Labels: 8L0-959-655-AI8.lbl
Part No: 8L0 959 655 L
Component: Airbag Front+Seite 7008
Coding: 01104
Shop #: WSC 01236
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 8L0-920-xxx-17.lbl
Part No: 8L0 920 980 R
Component: KOMBI+WEGFAHRS. VDO D11
Coding: 01444
Shop #: WSC 00137
1 Fault Found:
01304 - Radio
49-10 - No Communications - Intermittent
Address 22: AWD Labels: 02D-900-554.lbl
Part No: 02D 900 554 C
Component: HALDEX LSC ECC 0010
2 Faults Found:
00526 - Brake Light Switch-F
27-10 - Implausible Signal - Intermittent
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8D0 862 257 E
Component: CV-Pump, Alarm, RC D17
Coding: 15178
Shop #: WSC 00137
7 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01365 - Lock/Unlock Switch; Interior
29-00 - Short to Ground
00991 - Interior Lights
28-00 - Short to Plus
00955 - Key 1
09-00 - Adaptation Limit Surpassed
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 00000
Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00014
Shop #: WSC 01236
Address 56: Radio Labels: None
Part No: 8L0 035 195 H
Component: symphony II NP2 0151
Coding: 00201
Shop #: WSC 00272
End ---------------------------------------------------------------------
Monday,28,July,2008,20:03:14:37091
Im guessing her,
1st one means battery has either gone flat or been changed
2nd possibly is dodgy side airbag connector, under driver seat is often culprit
3rd bad connection between radio and instrument cluster, possibly at cluster end?
4th the brake light switch has been/is faulty
5th drivers door has activated alarm
to be honest, I would have hoped they would have cleared these all before they sold it to you....
