Audi A3 - 8P Hard Wire Question
I would like to hard wire my Road Angel into the fuse panel just inside the drivers side door.
Seems to be quite an easy job but which fuse should I use - I'd like to use a 'switched' fuse so the Road Angel turns off with the ignition ?
I was going to use the Cigarette Lighter (Fuse 24) but this seem to be permanently live.
Any help and advice would be much appreciated :)
If you google "add a circuit" there will be an adapter you can buy that lets you add to the fuse panel by doubling up a fuse then its just a matter of finding a circuit that is ignition live.
Alternatively there is bound to be a live under the dash somewhere you can pick up, the stereo will most likely be can so don't try there.
If you have a multimeter should be quick to find a suitable feed.
Awesome link, cheers! Mine has been just slotted into the fuse holder for the last 12 months, but this liitle adaptor will do a proper tidy job.
Many thanks
Guest
Reply to this topic...
  Only 75 emoji are allowed.
