smoking
mucker27
my vw passat 1.9tdi 130 bhp smokes heavy when accelerating off even if not booting it ,when ticking over it fine has anyone got any ideas what this could be ive had the injector s , exhaust and cat cleaned but too no avail . car done 40k and serviced up to date Can you help please .
Without wanting to sound patronising, there's probably nothing wrong with it, People who aren't used to diesels always say they smoke a lot but can only see it at night in other peoples headlights.
It's perfectly normal for a car of that age, with the newer Euro4 emissions vehicles with particulate filters, there is a lot less smoke, but you still see it at night.
A good Italian tune up every now and again does help blow the soot out and reduce the smoke a bit.
I'd agree with Shark then in that case.
Check all the air hoses and connections very carefully, if possible, remove and inspect them, as it's possible for leaks to only show themselves once the system is pressurised by the turbo, as they can then close up again once boost pressure is removed.
I wouldn't have thought it'd be the injectors as I think you'd notice poor/rough running, and the piezo injectors are very reliable on the PD engine.
