colnago Posted December 2, 2008 Report Share Posted December 2, 2008 hi i noticed my left front wheel is not straight. 1. it's not parallel with the other wheels and 2. secondly it is tilted vertically. I've put the wheel of and the arm going to the steering house is not straight, only at the end. I would like to know if the steering arm consist of two parts, connected by the bolt colored green. If that's true, i can replace the end part. If it's not true i have to replace the whole steerer ****. What about the vertical tilt? Which suspension arm is most likely to be twisted? Link to comment Share on other sites More sharing options...
Figure11 Posted December 2, 2008 Report Share Posted December 2, 2008 Wow. That is Fubared!!! You can change it by undoing the nut and unscewing it from the steering arm. I would suggest that at some stage you've his something solid. My guess would be that both the upper arm are bent. I would replace all control arms on thet side. Meyle do a set for replacement. Search the forum for Meyle. Mike Link to comment Share on other sites More sharing options...
harpersimon Posted December 3, 2008 Report Share Posted December 3, 2008 I wouldn't trust the rack to be any good either after whatever caused that to bend!? Link to comment Share on other sites More sharing options...
Figure11 Posted December 3, 2008 Report Share Posted December 3, 2008 After thinking about it for a while that track rod end bolts into the hub carrier. If it is out of true than the hub carrier may be bent, Can we have a photo of the suspension with the wheel off? Mike Link to comment Share on other sites More sharing options...
colnago Posted December 4, 2008 Author Report Share Posted December 4, 2008 I removed the bolt on the steering arm and the thing came off easy. Now the wheel is not pointing in the wrong direction, let's hope the steering arm is further straight, I will see this if I mounted the new end part. Now the wheel is just turned inwards. I think the lower suspension arm is not straight. I will make a photo tomorrow. Link to comment Share on other sites More sharing options...
