tmh-007 Posted March 28, 2009 Report Share Posted March 28, 2009 I’m trying to fit DIS only and need to ground the pin for the washer level empty, assuming it is pin1 of the blue connector is behind the instrument cluster how do you get to it?? Please help as I have the steering wheel removed ect, Many thanks Tmh Link to comment Share on other sites More sharing options...
shark_90 Posted March 28, 2009 Report Share Posted March 28, 2009 I've just replied to your email, but you need to remove the bottom part of dashboard trim (the bit that the OBD connector resides in), reach up behind the steering column to the dash cluster, and unplug the left-hand connector in the back of the dash cluster. You need to put a wire in Pin 1 of that connector and connect it to ground/washer sensor if you have fitted one. Link to comment Share on other sites More sharing options...
