jhono Posted April 6, 2009 Report Share Posted April 6, 2009 hi i have a55 plate tdi a3 and want to change the stereo to a pioneer,what leads would i require to do this,pulled out the concert unit in it and there ar two aerial leads confused:confused: Link to comment Share on other sites More sharing options...
Phil_S Posted April 6, 2009 Report Share Posted April 6, 2009 i belive audi's headunits power the arial cable somehow, that could be what the second plug is for, could be wrong though, one of the other guys on here should clarify it for you Link to comment Share on other sites More sharing options...
dq1 Posted April 7, 2009 Report Share Posted April 7, 2009 Not sure my self but you can try these chaps. I got the lead required for my 2000 A3 1.8T from them WWW.AUTOLEADS.CO.UK | Complete Car Database Link to comment Share on other sites More sharing options...
jhono Posted April 7, 2009 Author Report Share Posted April 7, 2009 cheers guys,behind the dash there are two aerial leads,one small one normal got an aerial adapter witch uses the small connector and the blue amp lead from the set this then plugs in to the back of the set as nomal,how ever this still leaves the normal aerial connector from the car,what do i do with this.:confused: Link to comment Share on other sites More sharing options...
