vk1tx Posted June 21, 2009 Report Share Posted June 21, 2009 Hi All, There is an exsessive amount of White smoke now and again coming from the exhaust when I am at a set of traffic lights for awhile then when I accelerate hard up a ramp on a uphill road to a freeway. Also sometimes if the car is not driven for a few days and on start up as well. By excessive I mean an embarrasing amount of white smoke almost not seeing the car behind me. BUt I stress only sometimes ,NOT always. Any body have any suggestions to why this is happening? Link to comment Share on other sites More sharing options...
Tipex Posted June 22, 2009 Report Share Posted June 22, 2009 Check the simple things first, is the oil level correct? not been over-filled? Otherwise, I'd imagine it's going to be either valve stem seals, piston rings or head gasket. Link to comment Share on other sites More sharing options...
vk1tx Posted June 24, 2009 Author Report Share Posted June 24, 2009 Hi Thanks, One thing I forgot to tell you that , ALL the Lifters thats 24 of them have been replaced by the Porsche dealer, and this has happened since that replacement. Maybe they did fill the oil tank a bit too high , will check via dipstick and not electronic readout on dash. Cheers, Alex Link to comment Share on other sites More sharing options...
bullett Posted July 7, 2009 Report Share Posted July 7, 2009 White smoke is normally steam/water. I'd check your water levels for the cooling system. Although I guess it could be the RMS issue. Has this been replaced on your car? Link to comment Share on other sites More sharing options...
