Booze and antibiotics
Booster
No adverse interaction normally occurs between alcohol and amoxicillin.
There is some evidence that alcohol delays the absorption of amoxicillin but it does not affect the total amount absorbed.
A couple of beers will be fine.
The above doesn't mean that it's fine to have loads either though, as that's just not clever if you need to take antibiotics.
Edited by Drinks
Some AB's and booze are a complete no no.
Amox is low strength, so should be fine. I was told it's not just that the alcohol destroys the benefit of the AB it's also to do with fluid level.
4 beers might not break down the AB benefit, but drunk quickly and thus p1ssed out soonish after, flushes the AB out not giving the body a chance to absorb the AB (hope that all makes sense!) +++
Some antibiotics do interact with alcohol and the reaction can be quite severe.
The problem with mixing alcohol and antibiotics in general is that alcohol in the main does your body no favours, especially if you are sick. This is the usual rationale behind avoiding alcohol and antibiotics where there is no interaction.
Amoxicillin can cause nausea and dizziness and alcohol can make these symptoms worse.
It would make sense to wait at least an hour after taking the amoxicillin before starting drinking to give the body a chance to absorb the drug before alcohol is introduced to the system.
As well as the absorption issues, alcohol breaks down beta-lactam antibiotics quickly and makes them ineffective. As with all antibiotics you need to finish the course, but with beta-lactams and booze, you've rendered some of your treatment inactive.
Antibiotics take a while to accumulate in the body, so be careful.
There is nothing in the handbook of medicines concerning amoxycillin and booze.
alcohol breaks down beta-lactam antibiotics quickly and makes them ineffective. .
thats a new one on me - which book of clinical pharmacology did that one come from?
beta lactamase enzymes can break down the beta lactam ring - not aware alcohol can do this, as it does not contain these enzymes (or any)
