yassers8 Posted January 31, 2010 Report Share Posted January 31, 2010 (edited) HI guyz, My 2001 S8 has this problemsince 3 weeks, the fresh air blower motor sometime do not work, and after turning the the AC button inside the car for about 7 times( ON & OFF ), then it will work, pluse that I had open the cover for the freshair blower motor and cleaned all the dirt leaves around it, but the cause came as I mention above, any advice any recommendtion please. S. YASSER Edited January 31, 2010 by yassers8 Link to comment Share on other sites More sharing options...
A8 Chris Posted February 3, 2010 Report Share Posted February 3, 2010 It's the blower motor sticking. There is an excellent pictoral write up here: audipages Fresh Air Blower Replacement I had same trouble with my 94 A8. Followed the above instructions so far, but even with offset screwdrivers, I could not get the motor cover off. My solution- Spayed good amount of ACF-50 through the plastic blades. Also drilled small hole in the central plastic cover over motor, and sprayed more ACF in there. Turned the plastic fins by hand until motor spun freely. No problems since. Hope this does the trick for you. Chris Link to comment Share on other sites More sharing options...
yassers8 Posted February 3, 2010 Author Report Share Posted February 3, 2010 (edited) Thanx for your replay dear, I hope it work also with me. I tried harder today to make it work while coming back from work but no use, I sweat to much from hot claimte man, belivte or not, when I reached home it works, I'm getting mad about it. but I'll try your idea. thanx again yasser It's the blower motor sticking.There is an excellent pictoral write up here: audipages Fresh Air Blower Replacement I had same trouble with my 94 A8. Followed the above instructions so far, but even with offset screwdrivers, I could not get the motor cover off. My solution- Spayed good amount of ACF-50 through the plastic blades. Also drilled small hole in the central plastic cover over motor, and sprayed more ACF in there. Turned the plastic fins by hand until motor spun freely. No problems since. Hope this does the trick for you. Chris Edited February 3, 2010 by yassers8 Link to comment Share on other sites More sharing options...
