pinhead1000 Posted May 10, 2010 Report Share Posted May 10, 2010 hi all in january i had a new air mass sensor fitted at midland vw about a month ago the power started to go in my mk4 golf 1.9 gt tdi t plate again so i took it back and they said that the air mass was fine and that my turbo had gone and wanted £850 for a new turbo i didnt think it was so went to another garage and they have told me that its could be the actuator on the back of the turbo or something like that but they said that you cant get them on there own you have to buy a new turbo is this correct if not can any 1 help me out as to where i can get 1 please the car dont pull till about 2500revs got no smoke the turbo whistles loud could the info from the second garage be correct? i hope some 1 can help me out this problem is driving me mad many thanks in advance pinhead1000 Link to comment Share on other sites More sharing options...
Pieman6484 Posted May 17, 2010 Report Share Posted May 17, 2010 The only way to find out for sure mate is to use Vag-com, You didnt mention what engine your running either I have an ASZ 130 TDI engine n have been plagued with the engine going into limp mode for ages. Vag com revealed a dodgy Air mass sensor and temperature sensor all seems well now for me Important notes Only use a genuine BOSCH Air mass there sods for going down but the non genuine items are even worse Dont believe these articles you read online about coked up turbos on ASZ engines although the Boost solenoid is a common fault it doesn't mean you need to fork out for a new turbo Im not a mechanic but all this info has come from a VAG specialist and iv used him for years Hope this helps Si Link to comment Share on other sites More sharing options...
pinhead1000 Posted May 18, 2010 Author Report Share Posted May 18, 2010 hi m8 thanks for the reply i have the 110 bhp engine, ive tried another genuine bocsch air mass and it was still the same. vw midland reckons its my turbo but the other garage i took it to reckons the actuator has seized on the turbo. ive rang round about 20 different places and they all say that you cant buy the actuator on its own, and to be honest im at the end of wits now m8 i just wish there was some where that could help me out. ive heard peeps on about vag-com but dont really know anything about it to be honest. many thanks pete Link to comment Share on other sites More sharing options...
cruiser647 Posted May 19, 2010 Report Share Posted May 19, 2010 Ask this inanother section of TSN. In the General Area, you can ask for help and ask is there is some-one local to you with VAG-Com or get to Meeting where someone might have VAG-Com and can help you out. Link to comment Share on other sites More sharing options...
Pieman6484 Posted May 19, 2010 Report Share Posted May 19, 2010 If your local to notts I can point you in the direction of someone that can Link to comment Share on other sites More sharing options...
Mook Posted May 19, 2010 Report Share Posted May 19, 2010 You can't buy the actuator on its own, but you could try a used one by buying a second hand turbo. It's very unlikely that the actuator itself has seized (it opens the wastegate when the N75 valve tells it to by re-directing air from the turbo inlet pipe - vacuum does the rest). Check all of your charge pipes (from the turbo to the intercooler then from the intercooler to the throttle body) - it sounds like you may have a split pipe. As ever, it's very hard to diagnose anything remotely, so finding a VW specialist with VCDS will help you find out what the problem is. Link to comment Share on other sites More sharing options...
Pieman6484 Posted May 21, 2010 Report Share Posted May 21, 2010 it could even be the relay that controls the system, its not definet but its not unheard of Link to comment Share on other sites More sharing options...
pinhead1000 Posted October 11, 2010 Author Report Share Posted October 11, 2010 (edited) hi guys im still having probs with my mk4 gt tdi ive changed all the pipes from rubber hoses from the turbo to the intercooler and from the intercooler to the turbo. had a diagnostic and its came up with somthing about my exhaust system and was told by the chap that i was probs the throttle body full of **** so ive cleaned that and still no good the fault code it came up with was p1114 and g70 i think do these codes ring any bells with any 1 as i say ive already tried ca genuine bosch MAF and it was still the same ive also tried unplugging the MAF to see if it runs any different and it runs the same any more ideas? many many thanks in advance pete Edited October 11, 2010 by pinhead1000 Link to comment Share on other sites More sharing options...
