gewiss1234 Posted July 6, 2010 Report Share Posted July 6, 2010 Hi. Just thought I'd try and see if anyone has an idea on this. Never seen it on any vw tdi. Sinario: going down road at 40mph revs say at 3500rpm let foot off accelorator car jerks wanting to go forward (engine should be braking) Fault. At 40 mph 3500rpm let foot off accelorator nudge into neutral without touching clutch or accelerator, revs stay at 3500 (hence jerking forward when in gear). Depress clutch engine revs return to normal. You can set the engine revs at whatever you want until you depress clutch . If you press the clutch quickly in and out the revs stay again but at the point where the clutch was let up . (microswitch under clutch pedal seems to controls this. Checked: MAF ECG, leaks in positive pressure system( N75 ok). Turbo seems fine pulls hard. Although I think its sensor ecu related. EGR cleaned and working No fault codes. Road test showing all perameters ok. Checked pedal actuator cant see a problem. only thing left ecu?? Thought I new these engines???? Any help welcome? THANKS+++ Paul Link to comment Share on other sites More sharing options...
gewiss1234 Posted July 6, 2010 Author Report Share Posted July 6, 2010 sorry thought i'd posted in passat. its a B5 passat 2000w 1.9tdi PD thanks:rolleyes: Link to comment Share on other sites More sharing options...
Cuprabob Posted July 6, 2010 Report Share Posted July 6, 2010 It's almost as if cruise control was switched on and disengaging when you put your foot on the clutch. Link to comment Share on other sites More sharing options...
