Magic_Wond Posted August 9, 2010 Report Share Posted August 9, 2010 After 14 month's respite from the previous gearbox troubles I had on my '97 4.2QS, they are back with avengence. Struggled to get the car home in limp mode this evening as even the slightest gradient caused it to almost grind to a halt. Engine just revs its nuts off and won't change up to 4th/5th. I changed the fluid/filter etc in June last year and this seemed to cure the same problem back then. Could the same issue have returned after only a year? (< 20K miles since then). Or has my torque converter finally surrendered? Difference this time is that the engine just revs in 3rd (I think) whereas last time it still went in to 4th/5th even in limp mode. Here are the codes :- 17118 P0734 Gear 4 - incorrect ratio 17119 P0735 Gear 5 - incorrect ratio 17114 P0730 Gear Ratio Control - incorrect ratio 17087 P0703 Torque converter/Brake Switch B Circuit - Malfunction Could a fault in the F125 switch generate the P0730 and P0703 codes? Any advice welcome - at my wits end with this gearbox and car's fate hangs in the balance as its going in for another fluid & filter change this Wednesday....... Link to comment Share on other sites More sharing options...
Magic_Wond Posted August 11, 2010 Author Report Share Posted August 11, 2010 Just a thought -any chance these symptoms and fault codes could be caused by a faulty F125 switch??? Link to comment Share on other sites More sharing options...
Architex mA8tey Posted August 11, 2010 Report Share Posted August 11, 2010 From Ross Tech Wiki if this helps - 17118/P0734 - Gear 4: Incorrect Ratio Possible Causes Wiring and/or connections faulty Sensor Gear Position Indicator faulty Gear Solenoides faulty Mechanical failure Possible Solutions Check wiring and connections Check Sensor Gear Position Indicator Check Gear Solenoides 17119/P0735/001845 - Gear 5: Incorrect Ratio Possible Symptoms Clutch Slipping Reduced Power Output Possible Causes Gear related Clutch slipping/faulty Gear related Solenoid Valve dirty/faulty Overloaded Clutch due to continuous high Torque or Tuning Wiring and/or Connections faulty Sensor Gear Position Indicator faulty Mechanical Failure Possible Solutions Check Engine Values for Plausibility, especially Torque related ones. Check Wiring and Connections Check Sensor Gear Position Indicator Check Gear Solenoides Special Notes The gear monitoring of the transmission control module checks the gear ratio by comparing transmission input and output speed in regard of the currently selected gear. This fault code is being set when recognizing an implausible transmission ratio. 17114/P0730/001840 - Gear Ratio Monitoring: Incorrect Gear Ratio Possible Symptoms Malfunction Indicator Light (MIL) ON Possible Causes Transmission Fluid contaminated Transmission faulty (Mechanical Problem) Possible Solutions Check Transmission Fluid (Color and Contamination) Replace Transmission Fluid when necessary Check Transmission Mechanics Special Notes Transmission Damage may be caused by Engine Problems, make sure there are no other/relevant Fault Codes stored in Engine Control Module. 17087/P0703/001795 - Brake Switch (F): Electrical Malfunction Possible Symptoms Malfunction Indicator Light (MIL) ON Possible Causes Wiring and/or Connector(s) from/to Brake Switch (F) faulty Brake Switch (F) faulty Possible Solutions Check Wiring and/or Connector(s) from/to Brake Switch (F) Check/Replace Brake Switch (F) Special Notes When found in Vehicles with Drive-by-Cable (DBC) the Brake Switch (F) is connected to the Transmission Control Module. On older Models this Code is stored automatically after Terminal 15/Ignition is switched ON. If the Brake Switch (F) is OK you can avoid this Fault Code by pressing the Brake Pedal after switching on the Ignition and prior to checking Fault Codes. The Code should automatically be cleared then. When found in Vehicles with Drive-by-Wire (DBW) the Brake Switch (F) is connected to the Engine Control Module In this case you should check the Engine Control Module for Fault Codes as well and the Data Bus Wiring between Engine and Transmission Control Module. Link to comment Share on other sites More sharing options...
Magic_Wond Posted August 11, 2010 Author Report Share Posted August 11, 2010 As feared the gearbox is toast. Fluid was fried and full of metal particles, and after one short drive on new fluid & filter the fluid was burnt and filthy again and the magnets covered in metal. Appear the box has a serious internal problem and is effectively grinding metal. I've decided to cut my losses and call it a day, so if anyone is in the market for a 1997 4.2 QS (pre FL) with 149K on the clock for spares or repair I'm open to offers (collection only!!). Car is in excellent condition for year bar the knackered gearbox (pics available). Gutted at this outcome but c'est la vie.....if someone is willing to either take on a project or spend £1500 on a gearbox overhaul then they will have themselves a great car. Otherwise its up for spares/breaking. Link to comment Share on other sites More sharing options...
