Audi a3 2007 headlamp fuse position needed please
Dirtydiesellee
Sorry, unable to help on this, But i would expect there to be 2 fuses. Usually for safety reasons they split the circuits so they don't both go out if one fuse blows.
That aside have you considered...
1. If your in the UK,100W lamps will be illegal.
2. If you uprate the fuse(s) is the wiring, switchgear, relays, bulbholders, headlight assemblies themselves rated to take the extra current and heat without causing a fire.
