teame Posted September 17, 2010 Report Share Posted September 17, 2010 I added cruise control on the Audi A4 (B6-8E, 2001), but I have a problem. Everything looks ok, but CC do not work. when I look with vag-com 16-Steering wheel, 08-meas. block - Group 4, I can see that added CC works. Also on 01-Engine - 08-meas. block- group 6 I see that CC work, I can turn it OFF and ON, when I press break, gas pedal, but nothing happens when I press clutch Also I am enable CC on engine with LOGIN 11463 Here is my AutoScan Chassis Type: 8E - Audi A4 B6 Scan 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76 -------------------------------------------------- ----------------------------- Address 01: Engine Controller: 038 906 019 begin_of_the_skype_highlighting 038 906 019 end_of_the_skype_highlighting CG Component: 1,9 l R4 EDC G200SG 1360 Coding: 00002 Shop #: WSC 63351 No fault code found. Readiness: N / A -------------------------------------------------- ----------------------------- Address 03: ABS Brakes Controller: 8E0 614 517 Component: ABS / ESP front D620 Coding: 04,255 Shop #: WSC 67458 No fault code found. -------------------------------------------------- ----------------------------- Address 08: Auto HVAC Controller: 8E0 820 043 A Component: A4 Klimaautomat 0403 Coding: 00000 Shop #: WSC 63351 No fault code found. -------------------------------------------------- ----------------------------- Address 09: Cent Elect. Controller: 8E0 907 279 Component: int. Lastmodul RDW 0409 Coding: 00001 Shop #: WSC 63351 No fault code found. -------------------------------------------------- ----------------------------- Skipping Address 15-Airbags -------------------------------------------------- ----------------------------- Address 16: Steering wheel Controller: 8E0 953 549 N Component: Lenksáulenmodul 0308 Coding: 00,041 Shop #: WSC 67458 No fault code found. -------------------------------------------------- ----------------------------- Address 17: Instruments Controller: 8E0 920 900 EX Component: KOMBI WEGFAHRS. RB4 D14 Coding: 00,301 Shop #: WSC 01601 WAUZZZ8EZ1A012010 AUZ6Z0Y0029467 No fault code found. -------------------------------------------------- ----------------------------- Address 46: Central Conv. Controller: 8E0 959 433 J Component: Komfortgerát T85 0111 Coding: 06,768 Shop #: WSC 63351 3 Faults Found: 01562 - Right Rear Door 61-00 - Will not De-Safe 01331 - Door Control Module: Driver Side (J386) 80-00 - Single-Wire Operation 01560 - Passenger Door 61-10 - Will not De-Safe - Intermittent -------------------------------------------------- ----------------------------- Address 56: Radio Controller: 8E0 035 152 Component: chorus II GRO 0001 Coding: 00002 Shop #: WSC 63351 No fault code found. End ------------------------------------------------- ------------------------------------------------- Can You help me. Link to comment Share on other sites More sharing options...
S4_marv Posted September 20, 2010 Report Share Posted September 20, 2010 It's quite possible that you've got a broken clutch pedal sensor. It's apparently fairly common, and you wouldn't really notice it unless you've got cruise control, because I don't think it's used for anything else. It's probably worth replacing this part, and it will probably solve your problem. Link to comment Share on other sites More sharing options...
NathanA Posted October 2, 2010 Report Share Posted October 2, 2010 Got the same problem, even bypassed the clutch switch and nothing. Have had the battery disconnected overnight, recoded, nothing. I've bought another cc arm just to see if that helps. Link to comment Share on other sites More sharing options...
S4_marv Posted October 4, 2010 Report Share Posted October 4, 2010 Have you made sure you have a CC compatible steering module? Link to comment Share on other sites More sharing options...
NathanA Posted October 6, 2010 Report Share Posted October 6, 2010 Have you made sure you have a CC compatible steering module? Yep. Actually fitted an RS4 one and it didn't work. Due to ABS troubles I then got a new SWCM (with the Q suffix although R is recommended) and no joy. VCDS does pick up the movements of the stalk and have activated it in the engine module but nada. Link to comment Share on other sites More sharing options...
S4_marv Posted October 7, 2010 Report Share Posted October 7, 2010 weird... I'd try getting in touch with Shark_90 on these forums, either by PM, or through his company www.sharkperformance.co.uk. I suspect he'll be able to recommend a next course of action, or fix it for you for a reasonable charge. Link to comment Share on other sites More sharing options...
