jafferman Posted February 13, 2012 Report Share Posted February 13, 2012 ello I was hoping for some advice, Last week I saw the brake light switch problem, so i replaced it. Worked perfect for a week, then as soon as the snow hits us I get the lights all over again. Check engine light, Traction control, EPC and the turn on as soon as you turn on the car, ABS Light turns on as soon as i move. Would the fix be a new accelerator pedal? (Apparently I cant find just the switch itself) I saw there was a clutch switch brake switch and two switches on the accelerator. Heres my log Sunday, 12 February 2012, 18:00:44. VCDS-Lite Version: Release 1.1 Control Module Part Number: 8E0 909 518 AK Component and/or Version: 1.8L R4/5VT G 0003 Software Coding: 0016711 Work Shop Code: WSC 63351 VCID: 79856EE770D7 1 Fault Found: 18047 - Accelerator Position Sensor 1/2 (G79/G185): Implausible Signal P1639 - 008 - Implausible Signal ************************************************** ************************************************** ************************************************- Sunday, 12 February 2012, 17:59:13. VCDS-Lite Version: Release 1.1 Control Module Part Number: 8E0 614 517 A Component and/or Version: ABS/ESP allrad 3429 Software Coding: 04275 Work Shop Code: WSC 93168 VCID: 263F759BD1E9 2 Faults Found: 00526 - Brake Light Switch-F 27-00 - Implausible Signal 01314 - Shareware Version. To Decode all DTCs 79-00 - Please Register/Activate ************************************************** ************************************************** ************************************************- Link to comment Share on other sites More sharing options...
