a900ss Posted April 15, 2004 Report Share Posted April 15, 2004 Hi, Any thoughts on this particular problem? 10 day old 1.8T Ltd Edition that makes a scraping cracking noise when pulling away. It sounds very much like the noise you hear when you scrape bellypans on high speedbumps on kerbs but it isn't that and nothing is hanging from the car. It only makes the noise the first time you pull away from cold and then it won't make it again until the next first pull away from cold. It happens in both first or reverse gear, whichever you happen to first engage in the morning. Also, it always happens at about the same time as the cluth is about 2/3 released. Any ideas? Clutch isn't slipping but it sure sounds like a drivetrain problem. Or maybe could it be a starter motor issue? It only happens once, the first time after the car has been started. I am sendig the car back to get it sorted but if anybody else has experienced the same, I'd like to know what it is. Thanks Link to comment Share on other sites More sharing options...
Snail Posted April 15, 2004 Report Share Posted April 15, 2004 Does it only happen when turning the wheel, or does it happen when driving in a straight line? my power steering grumbles a bit if you turn the wheel when not moving, especially when pulling away from a standstill when cold. Link to comment Share on other sites More sharing options...
EdIver Posted April 15, 2004 Report Share Posted April 15, 2004 I get this every time when I move away in 1st. If I have reversed first then there is no problem but when it happens it feels like a slight knocking from under the engine compartment. Haven't worried about it particularly - just thought it was a "feature" of the car... Ed Link to comment Share on other sites More sharing options...
a900ss Posted April 15, 2004 Author Report Share Posted April 15, 2004 Not connected with steering. It is booked in for Monday and let us see what happens. If it is a feature of the car, it certainly is a strange one. Link to comment Share on other sites More sharing options...
Skid Posted April 15, 2004 Report Share Posted April 15, 2004 [ QUOTE ] Hi, Any thoughts on this particular problem? 10 day old 1.8T Ltd Edition that makes a scraping cracking noise when pulling away. It sounds very much like the noise you hear when you scrape bellypans on high speedbumps on kerbs but it isn't that and nothing is hanging from the car. It only makes the noise the first time you pull away from cold and then it won't make it again until the next first pull away from cold. It happens in both first or reverse gear, whichever you happen to first engage in the morning. Also, it always happens at about the same time as the cluth is about 2/3 released. Any ideas? Clutch isn't slipping but it sure sounds like a drivetrain problem. Or maybe could it be a starter motor issue? It only happens once, the first time after the car has been started. I am sendig the car back to get it sorted but if anybody else has experienced the same, I'd like to know what it is. Thanks [/ QUOTE ] Mine does that too. Figured it was a characteristic of the multitronic box. Let us know what happens at the dealer. Cheers m8 Link to comment Share on other sites More sharing options...
farhan Posted April 15, 2004 Report Share Posted April 15, 2004 Drove a s-line multitronic demo and it did not do this...perhaps a problem? Link to comment Share on other sites More sharing options...
homerj Posted April 15, 2004 Report Share Posted April 15, 2004 Sound like the brakes are ceasing up a bit and scrapping on the disks when you pull away initially. Or as I have had before a stone (gravel drive) is stuck in the brake and scratching on the disk. You may want to try reversing at speed hitting the brakes and then going straight forward and hitting the brakes, this freed it for me. If it is a stone you do not want to do any miliage as it can damage the disk permenately. Link to comment Share on other sites More sharing options...
kevinamarsden Posted April 15, 2004 Report Share Posted April 15, 2004 My 1.8t limited edition also does this. I actually think it's something to do with the climate control compressor. The same used to happen on the climate control on my Alfa and on my Leon Cupra. Certainly don't think it's anything to worry about but let me know if the dealer finds anything more sinister. cheers ! Link to comment Share on other sites More sharing options...
apreading Posted April 15, 2004 Report Share Posted April 15, 2004 I would tend to think Homer's analysis fits the sound I think being described. I get this if I wash the car without bypassing the water softener for the hose pipe - basically I think rust forms on the discs and bond them to the pads. If you leave it overnight like this you get a noise as the 'bond' is broken. Bypass the softener, take the car for a drive after washing to dry the brakes and it doesnt happen anymore... Link to comment Share on other sites More sharing options...
a900ss Posted April 15, 2004 Author Report Share Posted April 15, 2004 Thanks but it is unlikely to be the brakes. I am a 1000 mile a week man, and this noise happens everytime you first start the car and pull away. Even if you turn off for 30 seconds, re-start engine and pull away, it will still do it. If you leave engine running, it will do it at the first pull off but no more. Thanks for your help so far. a900ss Link to comment Share on other sites More sharing options...
apreading Posted April 15, 2004 Report Share Posted April 15, 2004 Quattro or FWD? Link to comment Share on other sites More sharing options...
Phantom Posted April 15, 2004 Report Share Posted April 15, 2004 I remember seeing a post just after I got my car 12 months ago discussing a similar noise when pulling away. As I have had two racks I know it is'nt this The post described something about the ABS system doing some sort of mechanical self check / reset just after you pull away. The noise sounds / feels as though it is coming from the bottom of the steering column on the driver's side. Mines a CVT and does it every time, I think it is just a characteristic of the car, but could be wrong. Would be interested to hear what your dealer says. Link to comment Share on other sites More sharing options...
dodgy Posted April 16, 2004 Report Share Posted April 16, 2004 Yep - I'll bet it's the ABS. Mine does it too. I think it even says it in the manual ... Link to comment Share on other sites More sharing options...
homerj Posted April 16, 2004 Report Share Posted April 16, 2004 [ QUOTE ] Thanks but it is unlikely to be the brakes. I am a 1000 mile a week man, and this noise happens everytime you first start the car and pull away. Even if you turn off for 30 seconds, re-start engine and pull away, it will still do it. If you leave engine running, it will do it at the first pull off but no more. Thanks for your help so far. a900ss [/ QUOTE ] Ah, thought it only did it from cold, unlikely to be the brakes sticking if it does it after you've been driving already. ^^^^^Think the guys above have got the answer anyhows ! Link to comment Share on other sites More sharing options...
a900ss Posted April 16, 2004 Author Report Share Posted April 16, 2004 Thanks for your help. It IS the ABS self-check system and all A4's should do it. Thanks all a900ss Link to comment Share on other sites More sharing options...
Phantom Posted April 16, 2004 Report Share Posted April 16, 2004 Tyresmoke technical support helpdesk comes up trumps again , this board provides a much better response rate than most Audi dealers ! Link to comment Share on other sites More sharing options...
kevinamarsden Posted April 16, 2004 Report Share Posted April 16, 2004 Job Done ! You'll probably get loads of posts from people who's cars dont clunk when they pull off now ! Link to comment Share on other sites More sharing options...
homerj Posted April 16, 2004 Report Share Posted April 16, 2004 [ QUOTE ] Job Done ! You'll probably get loads of posts from people who's cars dont clunk when they pull off now ! [/ QUOTE ] Oh christ theres another noise I'm going to start hearing now Link to comment Share on other sites More sharing options...
Skid Posted April 16, 2004 Report Share Posted April 16, 2004 [/ QUOTE ] Oh christ theres another noise I'm going to start hearing now [/ QUOTE ] I found another disturbing noise coming from the rear of the car after a couple of days Turned out to be a golf ball that had wormed its way our of the bag..... Think there's a moral to this story! Link to comment Share on other sites More sharing options...
Snail Posted April 16, 2004 Report Share Posted April 16, 2004 [ QUOTE ] [/ QUOTE ] Oh christ theres another noise I'm going to start hearing now [/ QUOTE ] I found another disturbing noise coming from the rear of the car after a couple of days Turned out to be a golf ball that had wormed its way our of the bag..... Think there's a moral to this story! [/ QUOTE ] I think its a similar lesson to the one david beckham is currently learning Alledgedly!!!! Link to comment Share on other sites More sharing options...
