Removing and Adjusting the Front Fog Lights
PaulW
Here are the instructions for removing/installing/adjusting the front fog lights:
Fog lights, servicing
Fog lights, removing and installing
WARNING!
Disconnect battery Ground (GND) strap before working on the electrical system.
Notes:
Obtain radio code before disconnecting battery.
Be sure to activate vehicle features (radio, clock, electric window regulators) according to owner's manual when the battery is re-connected.
Important notes:
To prevent contact corrosion, use only approved bolts, nuts, washers etc.
These items have a special surface coating and can be recognized by their greenish color.
These bolts must also be stored separately.
Removing
- Remove air grill by pulling latch -3- downward using a flat head screwdriver.
- Remove trim plate at fog light forward. Trim plate is secured with three latches -2-.
- Trim plate is inserted in guides -3- at fog light.
- Remove mounting screws -1-.
- Remove fog light from bracket -2- by pulling forward slightly.
- Disconnect electrical harness connector.
Installing
- Complete installation in reverse order of removal.
- Adjust fog light after installing
Fog lights, adjusting
- Adjust the appropriate adjustment screw using a socket wrench (6 mm) or a Phillips-head screwdriver.
- Turn adjustment screw counter clockwise to lower beam height. Adjustment screw can be accessed via hole -1- in air grill. Horizontal adjustment is not possible.
Fog light bulb, replacing
Removing
- Remove fog light
- Turn cover -1- in direction of arrow and remove it.
- Disconnect electrical harness connector at bulb.
- Disengage wire clamp -1- and remove bulb for fog light (12V 55W H3) from housing.
Installing
