PaulW Posted June 21, 2004 Report Share Posted June 21, 2004 Here are the instructions for removing/installing/adjusting the front fog lights: Fog lights, servicing Fog lights, removing and installing WARNING! Disconnect battery Ground (GND) strap before working on the electrical system. Notes: Obtain radio code before disconnecting battery. Be sure to activate vehicle features (radio, clock, electric window regulators) according to owner's manual when the battery is re-connected. Important notes: To prevent contact corrosion, use only approved bolts, nuts, washers etc. These items have a special surface coating and can be recognized by their greenish color. These bolts must also be stored separately. Removing - Remove air grill by pulling latch -3- downward using a flat head screwdriver. - Remove trim plate at fog light forward. Trim plate is secured with three latches -2-. - Trim plate is inserted in guides -3- at fog light. - Remove mounting screws -1-. - Remove fog light from bracket -2- by pulling forward slightly. - Disconnect electrical harness connector. Installing - Complete installation in reverse order of removal. - Adjust fog light after installing Fog lights, adjusting - Adjust the appropriate adjustment screw using a socket wrench (6 mm) or a Phillips-head screwdriver. - Turn adjustment screw counter clockwise to lower beam height. Adjustment screw can be accessed via hole -1- in air grill. Horizontal adjustment is not possible. Fog light bulb, replacing Removing - Remove fog light - Turn cover -1- in direction of arrow and remove it. - Disconnect electrical harness connector at bulb. - Disengage wire clamp -1- and remove bulb for fog light (12V 55W H3) from housing. Installing - Complete installation in reverse order of removal. - Adjust fog light after installing Link to comment Share on other sites More sharing options...
Sven Posted June 21, 2004 Report Share Posted June 21, 2004 Thanks Paul! I figured as much, but somehow 'latch #2' wasn't being very cooperative, so I thougt it'd be wiser to ask first and not apply brutal force to pull it out... Link to comment Share on other sites More sharing options...
PaulW Posted June 21, 2004 Author Report Share Posted June 21, 2004 I'm surprised they mention disconnecting the battery, I don't think I would do that....did you? Link to comment Share on other sites More sharing options...
gambba Posted June 21, 2004 Report Share Posted June 21, 2004 [ QUOTE ] I'm surprised they mention disconnecting the battery, I don't think I would do that....did you? [/ QUOTE ] It's safety first that's all. Link to comment Share on other sites More sharing options...
Sven Posted June 21, 2004 Report Share Posted June 21, 2004 It's an American manual.... $$$ue I wouldn't bother TBH. (Disclaimer: Don't do what I do, do what the manual says) Link to comment Share on other sites More sharing options...
