Gap between brake pads and discs
Chris_B
OK, here's an easy Q for you tyresmokers who are mechanically minded.
My rear brake pads sit about 5mm or so away from the discs (IIRC), but my front ones are much closer, in fact I think it would be hard to slip a sheet of paper between the pad and disc.
Is this right? Should the front pads sit so close to the discs? Wouldn't even the slightest warp of the front discs cause them to chafe against the pads while driving, causing heat?
Does this explain the squealing when braking and odd "foghorn" noises turning on full lock at low speed?
If the Audi setup is similar to most, then the caliper piston seals are responsible for pulling the pads back from the disc, effectively making them self adjusting. Slight scuffing is pretty normal, and nothing to be concerned about.
The rear brakes are different, as the handbrake mechanism pushes the pads out mechanically, along side the calipers pistons which push them out hydraulically. This may account for the difference, but I'm not sure what the Audi setup looks like.
There is no specific retract mechanism on disc brake pads - the pads just go back as far as the disc knocks them back. The braking effort is all down to how hard the pads 'squeeze' the disc. I'm surprised at the 5mm gap on the rear brakes, although this may be something to do with the handbrake mechanism, which also makes use of the rear pads. However, I would expect this 5mm gap to lead to a lot of dead movement in the brake pedal.
The pads will always rub the discs, but if there is any warp, the pads will be knocked back on the first turn of the wheel.
You can easily see the thickness of the front pads (and apparently the rears as well). If that's good, and the brakes work fine, I wouldn't worry a bit about the piggy. wink.gif
If it bothers you, you could ask the local tyre/brake fitter to apply some 'anti squeel'. F.i. Wurth DBQ2200 Disc Brake Quiet.
Ah, fate has conspired to have the dealer take a look at it - the damn inflatable lumbar support in my driver's seat 'popped' today, so I'll be in on Monday anyway, they can stick some anti-squeal paste on it and look at the slight vibration at 55mph.
I think she's got wind of the replacement, and she's punishing me...
  • 1 month later...
Apparently the latest ESP system thats fitted to the NEW 2005 A4 applies the brakes some how during driving to ensure that there is no water on them in the rain to ensure good bite.... Strange but true.
A problem I got once on a short term Vectra I had, every time it rained I had to keep dabbing the breaks to get the water off the discs. Other wise if I suddenly had to break for a second all I got was a pause and no retardation at all until they started to grab.
Audi seem to have fixed that !
Disks generally dont get wet unless you drive through deep water, so I doubt very much that the brakes are applied to dry the disks. Sounds like a wind up.
It's real, it's a Bosch ESP+ feature. I think Merc were the first to use it on a production car.
  • 3 weeks later...
