talkingbollox Posted September 17, 2004 Report Share Posted September 17, 2004 Isn't the whole point of the valet key to keep your valuables from strangers? In other words if you've set the boot not to unlock without the key, the plastic one won't be able to open the boot, nor the glovebox. Shoot me down but this is how I understand it to work. Link to comment Share on other sites More sharing options...
Ari Posted September 25, 2004 Report Share Posted September 25, 2004 My understanding of the plastic key is this. It is to keep in your wallet so if you lose your car key you can still use your car. It will unlock the car manually even if locked with the normal key (no "plip" function of course so you have to stick in in the door lock and turn it) and it will start the car (has an immobilisor transponder). As it has no "plip" function it will not turn off the alarm when you unlock the car, however if you insert it into the ignition and turn ignition on it will stop the alarm from sounding. I've certainly heard nothing about it only working two or three times and it's not a valet key as it will do or access all that a normal key will, just not by remote control like the plip function. Valet keys are keys that just operate the door and ignition so you can give these to a valet and he can't get into the boot or glovebox (if locked). Valet keys have all but died off due to central locking on modern cars meaning that everything unlocks automatically anyway. So it is just a key to keep in your wallet in case of emergency. I took mine in my wallet when I went to France with the car earlier this year (plus gave girlfriend the spare key). Link to comment Share on other sites More sharing options...
nasse Posted September 29, 2004 Report Share Posted September 29, 2004 I was told that the plastic key is a spare key for cases when you lose your key, the battery in the key goes flat or you drop the key resulting in a broken transponder. If I remember correctly, the dealer adviced to first stick the plastic key in the ignition (transponder sends signal) and then use the normal key to actually start the car (this applies to the case when the normal key's transponder for some reason doesn't work). Link to comment Share on other sites More sharing options...
321allest Posted December 11, 2004 Report Share Posted December 11, 2004 sounds like you just gaffa tape it somehere secret and hope you remember where when you come out of the pub so pissed you've given your keys to the landlady and now you need somewhere to sleep cos surely plod can't get you if you can't start the engine with it - or can he cos he won't follow this will he? Link to comment Share on other sites More sharing options...
