poox Posted January 30, 2005 Report Share Posted January 30, 2005 I need to get my diff oil and filter changed, can I get this done at AmD instead of using a stealer without anything showing up that would void my warranty? thanks. Link to comment Share on other sites More sharing options...
Paul Posted January 30, 2005 Report Share Posted January 30, 2005 cant advise, i always get mine done at the dealer with each AVS service, as they are so close to each other. Link to comment Share on other sites More sharing options...
poox Posted January 30, 2005 Author Report Share Posted January 30, 2005 they quoted me £150, can you advise on that? Link to comment Share on other sites More sharing options...
Paul Posted January 30, 2005 Report Share Posted January 30, 2005 not at the moment mate, so far both my S3's have only needed an oil change. with the 1st AVS This S3's next service is the oil/filter one, when it goes in for its second AVS Link to comment Share on other sites More sharing options...
Gren Posted January 31, 2005 Report Share Posted January 31, 2005 [ QUOTE ] they quoted me £150, can you advise on that? [/ QUOTE ] Sounds a little high. Only had the oil change on mine so far but it cost around £70. Filter can't cost much and won't add a lot to the time. Doubling doesn't sound right. Then again I found differences of around £100 amongst dealers for my first AVS service. AmD will do just as good a job but you'll lose you FASH. May be an issue for you? Link to comment Share on other sites More sharing options...
