K&N airfilter
bhalstad
Apparently, the standard K & N is OK, but once washed and re-oiled, then it can causes probs.
Enthusiastic oiling can cause the oil to 'spray' off onto the MAF and cause duff readings. Or burn it out.
A solution, is to use a cone filter rather than a panel jobbie. (eBay has loads and you do not HAVE to get your specific model one). You will have to make up your own pipes and use a bit of gaffer tape, but it should fit in the airbox. Make sure you keep the MAF in-line and do not damage it. I used stuff from B&Q pipe section, gaffer tape and a small tin can to connect my cone filter to the air pipe in the air box. You need to have a cold air feed too - hence the filter is still in the airbox!
Hope that helps!
YOu often find that in many driving conditions with a 1.8T a straightforward K&N induction kit does not offer you any benefits. Testing a similar kit on my TT had 275bhp before and about 250bhp after!!!!!! basically you get a lot of heat build up in certain conditions meaning the engine draws in a lot of hot air and I forget the exact equation but it roughly works out that a +1deg rise in intake temp can lead to a -1bhp power figure (that may not be accurate but it is something along those lines). So in standing traffic and around town an induction kit might offer you no benefit.
Now if you were to shield the cone with some heat shielding and run a cold air feed from under the car to the enclosure you could overcome this problem.
I ran a panel K&N on my 1.8T for 3 years without a wiff of a problem. Have now been running one on my R32 for 16 months without issue.
I have been using them for years and not once have they cause me any problems.
I'd avoid the exposed cone filters as they will suck in hot air from the engine bay and reduce power. The panel filters are loacted in the stock air box, which is made of a heat resistant material, which ensures that the air entering the airbox from outside is not 'warmed' by heat from the engine within the engine bay.
Don not over clean or over oil. Best to clean every 25,000 miles or if it gets super dirty, ie you live in a fly / bug ridden part of the world.
But that just my opinion, you may wish to seek others advice to either back this up or refute it smile.gif169144-ok.gif
NO it's not an opinion, it's a fact based on factual events. I too always fit a K&N and have never had any problems. Anyone that moans about them is just talking dung.gif. I can back you up, Panel K&Ns allow your engine to breath more easily and that's got to be good. 169144-ok.gif
NO it's not an opinion, it's a fact based on factual events. I too always fit a K&N and have never had any problems. Anyone that moans about them is just talking . I can back you up, Panel K&Ns allow your engine to breath more easily and that's got to be good.
Ditto! But now I have a TD, I have fitted a cone filter in the airbox. Just need to give it some more holes now for more air and let the engine 'Breathe'........
Just a thought. Given that the same standard air filter flows adequately for a 3.2 ltr V6 in an R32, why the need to start increasing airflow by changing the filter for a TDI or a 1.8T? You aren't going to make it breathe any better as it's flow capabilities are much more then the engine requires.
If you were going down the route of modding the engine then you might need to open things up a bit when you really start to flow some air through it, but standard and mild modding, no need.
In new form the standard paper filter and K&N type filter aren't going to be that much different, except you'll get a better, smoother flow from the K&N, but only marginally.
After only a few thou miles tho the paper one will degenerate in terms of flow and performance will suffer. K&N will take a lot longer to show signs of reduced performance.
You buy an K&N once, and at around £45 it will last a good 50,000 plus miles (they say 100,000) where as you really want to be changing a paper one every 8,000 or so and thats 5/6 papers ones, at approx £22-£25 per paper filter you're near £100 on paper filters compared to a one off purchase on the K&N !
There's a guy I know who runs a 90 bhp TDI with the standard air filter and has fitted a CAT restriction gauge. This gives a visible reading of an decrease in airflow due to the blocking of the air filter. He runs 60k miles before he needs to change his. This might be a bit extreme, but is an indicator nonetheless. My car (130 tdi) runs up to 30k on longlife oil and the air filter gets changed then. Petrol engines may differ.
Can anyone tell me the K.N. part number for a 1.8T, as I'm having trouble finding the right one?
I've phoned K.N. but according to my local dealer it was the wrong P/N.
And for some reason this particular Passat model is not in their book.
Thanks for the info,but I'm still confused.
I still end up with 2 different part nos 33-2125 & 33-2675.
I think I'll have to take my air filter out and measure it, weather permitting. sekret.gif
What year or car? Most common is the 33-2125, but you may have a Passat that is slightly different?
