S3 ... N75 valve.
Paul
In case anyone gets an N75 fault in Vag Com, this is it.
It controls the wastegate on the turbo
if you get a fault code, Before assuming its dead, check it is still plugged in, all pipes are secure, and there is no holes in the pipe work.
you can see it and get to it without removing the engine cover, but probably easier if you do take engine cover off...
