ashforduk Posted May 14, 2005 Report Share Posted May 14, 2005 i have accessed my On-Board Diagnostic and it tells me i have a code 22.1 error and then it says Compressor remains off until switch closes ????? wat does that mean any ideas ? where is the switch ?? also i have just had my air con regases and fix (not by dealer) so that should work but error code still there.Plz help me if you can Link to comment Share on other sites More sharing options...
Milo Posted May 14, 2005 Report Share Posted May 14, 2005 Assuming there isn't a glitch with TSN this is the 4th time you have posted this. Once again see my reply here. Have you had the pressure switch checked/changed as this seems the most likely cause? Link to comment Share on other sites More sharing options...
