Ska Posted May 15, 2005 Report Share Posted May 15, 2005 Anyone know what sort of load a standard Battery can take? The reason why I ask is because my stereo system which comprises of the following is giong to draw about 130amps. Do you guys think I'll need to change it? If I do upgrade do I have to change the Alternator? I understand there is an Aux. BAttery above the main one in the boot for some 4.2quattro's, is this simply charged by the alternator using a split charge relay circuit and what do I need to install one into my V6 ACK i.e is the aux. battery ventilated or sealed etc. Stereo system list: Alpine TV/monitor + CD changer DSP EQ DVD palyer Rear TFT screen V12 4 channel amp V12 2 channel amp 2x10" type R subs ancillaries fans relays etc Yes I do live in my car and I'm working on installing a fridge later on Link to comment Share on other sites More sharing options...
Tobes49 Posted May 16, 2005 Report Share Posted May 16, 2005 The battery is just a storage unit. If your only going to be using the audio when the car running you might need a bigger alternator, Most A8 have 90AMP alternators with most bigger engines one comming fitted with 120AMP ones. Would have thought your best investment with that sort of system would be a power cap. This is like a very fast discharging battery. It will take the shock loads of the alternator when the bass line going. Link to comment Share on other sites More sharing options...
caveman Posted May 17, 2005 Report Share Posted May 17, 2005 no need for alternator..like tobes said u need a capcitor: here is some good info why u need one: http://www.electronixwarehouse.com/car/accessories/capacitors.htm also i highly recommend gell cell batteries...more expensive then regular but last alot longer and hold better charge.. http://www.optimabatteries.com/publish/optima/americas0/en/config/product_info/automotive.html Link to comment Share on other sites More sharing options...
Ska Posted May 17, 2005 Author Report Share Posted May 17, 2005 Cheers guys I'll give a try one of these caps, say a 1 Farad. Link to comment Share on other sites More sharing options...
