adeflowers Posted May 25, 2005 Report Share Posted May 25, 2005 After some useful help on my last query perhaps someone can help. I am now a proud & very Happy Owner of an S3, but the driver & passenger windows creek on the rubber seal when they are fully closed, I'm guessing I can lube the rubber with something?? The rest of the car is perfect so this small noise is quite annoying! It's mainly apparent when driving in town as the body flexes I guess over small bumps etc. Anyone suggest/help? Cheers. Link to comment Share on other sites More sharing options...
Tomk Posted May 25, 2005 Report Share Posted May 25, 2005 mine used to do this , give the rubber seals a realyl good clean with some spirits to get it nice and clean, then using vasaline start to work this in to the rubber... dont just put a coat on rub it in, or heat it up and use a paint brush to work it in if you dont want to get your hands mucky , worked a treat on my car Link to comment Share on other sites More sharing options...
MOSE Posted May 25, 2005 Report Share Posted May 25, 2005 AdeF.....TomK gave me the same advise a little while ago regarding a creek I had with the sides of my hood. I wiped these clean with a wet cloth. Dried it properly with a cotton cloth then lightly lined the seal with a petroleum based lubricant (wasnt Vaseline by the way - I did go out to get some but they only had this monster great pot and everyone was giving me wierd looks so left the shop with a Sunday Sport instead). Its worked wonders and has stopped the creaking. Have also tried this on the top of the windscreen area where the hood sits and locks, worked wonders there. Link to comment Share on other sites More sharing options...
Tomk Posted May 26, 2005 Report Share Posted May 26, 2005 must admit i do need to re doo mine, but its just a case of re generating the rubber ... Link to comment Share on other sites More sharing options...
runflat Posted May 26, 2005 Report Share Posted May 26, 2005 Like the Vaseline idea. I have used WD40 successfully..just spray a bit on and wipe it in. Must admit it only lasts a few weeks before it needs doing again, so I will try the vaseline. How long have you guys found the vas works? Link to comment Share on other sites More sharing options...
Tomk Posted May 26, 2005 Report Share Posted May 26, 2005 well mine needs re doing every summer, just to re generate the rubber and stop it perishing , only takes ten mins, Link to comment Share on other sites More sharing options...
runflat Posted May 27, 2005 Report Share Posted May 27, 2005 doesn't vaseline eat into rubber? It certainly does on latex rubber. This will cause it to degrade and perish in time. Just a thought before you all slap it on... Link to comment Share on other sites More sharing options...
Tomk Posted May 27, 2005 Report Share Posted May 27, 2005 well my car has been lubed up once a year and it seems ok ! Link to comment Share on other sites More sharing options...
adeflowers Posted May 31, 2005 Author Report Share Posted May 31, 2005 I'll give the Vas a proper try. After 800 miles this wknd it's getting annoying!! Thanks for the advise. Link to comment Share on other sites More sharing options...
adeflowers Posted July 18, 2005 Author Report Share Posted July 18, 2005 Right - just incase anyone looks back at this. Turns out it's not my windows creaking but the door seal against the body, the slight furry rubber trim around the door seems to have worn this so the rubber connect to the body! Mr Sheen seems to stop the creaking, but wondering about getting the door seals replaced but not sure on costs. Link to comment Share on other sites More sharing options...
dougy Posted July 25, 2005 Report Share Posted July 25, 2005 If you can get the door pannel off, there are a couple of fiber wheels that gide the cables for the window greese them and it should stop it did mine fine now no problems Link to comment Share on other sites More sharing options...
